Why am unable to use usb port and charging at the same time? via OnePlus 7 Pro
  1. Konda shivaradhan , via OnePlus 7 Pro , Jun 15, 2021 :
    Im trying to use this Pibox usb c to hdmi , usb port , c type charging port.
    The issue is , I can only use either charging or Usb , both wont work at the same time.
    How to fix this, pls help
  2. #2
  3. Artemus.
    Community Hero 2020 Jun 15, 2021
    Artemus. , Jun 15, 2021 :
    You can't use more than one item at a time.
    J4t1np4r3kh likes this.
  4. #4
  5. Z1612187578731
    Gingerbread Jun 15, 2021
  6. KluGe
    Lollipop Jun 15, 2021
    KluGe , Jun 15, 2021 :
    Well, as far as I know:
    This is one of the limitations in the USB specification ...
  7. Artemus.
    Things got removed, not much you can do. My guess is, it put too much strain on the USB port and so was disabled.
  8. Horsault
    Moderator Moderator Jun 15, 2021
    Horsault , Jun 15, 2021 :
    Beta testers are to test features. Many of those won’t be ported to stable ROM for various reasons. It’s a big caveat you’re aware of when you choose to become a beta tester.
    For instance a feature might be convenient, but risk can exceed benefit in some given scenarii so that it won’t be ported to stable build.
    So you can’t take “it worked in beta test ROM” as an argument.
    J4t1np4r3kh and McJader like this.
  9. Konda shivaradhan , via OnePlus 7 Pro , Jun 15, 2021 :
    Fine man, im not arguing here was trying to point out something which a lot Mobile streamers will go through , as a reputed company i wanted to make this an important feature IF IT CAN BE IMPLEMENTED WITHOUT ANY ISSUE.
    but why cannot i use charging and usb port? Forget hdmi I won't use it.
  10. J4t1np4r3kh
    OnePlus Accessory Tester Jun 15, 2021
    J4t1np4r3kh , Jun 15, 2021 :
    I guess they don't really pick and choose. It's just a holistic setup, it does one thing at a time 🤷‍♂️
    Artemus. likes this.
