Why Bluetooth turns on When using NFC?
  1. Greedygutz
    Cupcake Jan 3, 2018
    Greedygutz , Jan 3, 2018 :
    When using Android beam Bluetooth turns on and it is required for transfer. Is it is a problem or usually NFC needs Bluetooth?
  2. Peketr
    Gingerbread Jan 3, 2018
    Peketr , Jan 3, 2018 :
    NFC just sets up the connection, the actual file transfer is over Bluetooth. that is why you don't need to hold the devices together for the whole time.
    Greedygutz likes this.
  3. jcespi2005
    Ice Cream Sandwich Jan 3, 2018
    jcespi2005 , Jan 3, 2018 :
    NFC doesn't need bluetooth, but most of the times, NFC is used to connect bluetooth devices, so it activates BT.
    Im my case i use NFC to read my transportation card (NFC compliance), and no BT needed for that.
  4. Greedygutz
    Cupcake Jan 3, 2018
    I tried to transfer file from Op 5t to S8+.. BT didn't enabled when tried for first time but after that it use BT. So is this is a error or is it is always like this
