7
Battery/Charging
Why dash charging sometimes is not working?
  1. phantomvivek Cupcake Jul 27, 2016
    phantomvivek, Jul 27, 2016 :
    Okay, let me try this.
    #41
  2. LammyPictures Honeycomb Jul 27, 2016
    LammyPictures, Jul 27, 2016 :
    Dash Charging works fine for me. I'm using a TPU clear gel case on my OnePlus 3 and I just got to make sure the cable is connected (sometimes I underestimate how the the case/charge port connection is)
    #42
    SunSpear likes this.
  3. OPFanBoyTillEnd Honeycomb Jul 27, 2016
    #43
  4. Jamesst20 Jelly Bean Jul 27, 2016
    #44
  5. phantomvivek Cupcake Jul 28, 2016
    phantomvivek, Jul 28, 2016 :
    Not well at all. Updated to 3.2.2 through the OTA. Still cannot see dash charging on lock screen. Charging on a whole has been much slower than it used to be. Oh God, I have such high expectations from this phone to not go kaput like this!
    #45
  6. stephenboyo KitKat Jul 28, 2016
    stephenboyo, Jul 28, 2016 :
    Your avatar looks like one of those deadly viruses, maybe that's what's bugged your dash charger. Anyway it dash charges up to 80% and trickle charges the rest
    #46
  7. Jamesst20 Jelly Bean Jul 28, 2016
    Jamesst20, Jul 28, 2016 :
    Told you, you gotta do a full wipe and a full oxygen os clean install.
    1. Unlock bootloader
    2. Flash TWRP recovery
    3. Wipe system, cache, dalvik-cache, user data
    4. flash full OxygenOS 3.2.2 zip
    5. Reboot and enjoy for real
    #47
  8. avhuntik Cupcake Oct 6, 2016
    avhuntik, Oct 6, 2016 :
    today i charged my op3 for the first time and after plugging in for about an hour it was only 30% charge so i removed the charger then i noticed that the usb port of the cable was not properly plugged into the brick, so i pushed the cable properly in the brick after then the phone started charging quickly.. maybe that is your problem. let me know if you have the same problem...
    #48
  9. ChinChinati Jelly Bean Oct 6, 2016
    ChinChinati, Oct 6, 2016 :
    it wont dash charge when your wall power socket is getting lower voltages then usual or you charge with laptop. you need to use the dash charge adapter on a properly working power socket.
    #49
  10. F_Chettawan_Senapant_Lur Gingerbread Oct 6, 2016
    F_Chettawan_Senapant_Lur, Oct 6, 2016 :
    I got that once too but mine the charger side.
    #50
  11. stevegrasberg Cupcake Oct 6, 2016
    stevegrasberg, Oct 6, 2016 :
    No problem so far. Need a Dash Car Charger but it is out of stock. Any suggestion from other brands?
    #51
  12. Morttem Ice Cream Sandwich Oct 6, 2016
    Morttem, Oct 6, 2016 :
    Hi there.
    Yea same thing happened to me, but after that time everything works perfect and I just freaking love my OP3
    #52
  13. SirBacke Honeycomb Oct 6, 2016
    SirBacke, Oct 6, 2016 :
    I had similar things happening abroad. I just plugged in the charger into another socket and the problem was solved.
    #53
  14. Morttem Ice Cream Sandwich Oct 6, 2016
    The good thing is that it was just a "monohardware" issue (that's how we call it in Mexico sometimes LOL) it means that the problem was the person who was making the mistake
    #54
  15. ChinChinati Jelly Bean Oct 6, 2016
    it means that socket was not getting the right amount of voltage as usual. dash charge doesnt work in low voltages
    #55
  16. tomelwood Honeycomb Oct 6, 2016
    tomelwood, Oct 6, 2016 :
    I used a iPhone 6 for a little because I've always said I've hated iPhones and IOS, but haven't used one since my 4s. First reaction was Fuxk me it charges slowly, I gave it back after 2 days.
    #56
  17. SirBacke Honeycomb Oct 7, 2016
    SirBacke, Oct 7, 2016 :
    Maybe in Mexico this is so. In Europe you only can plug in and then it loads fast or slow. If it would not load at all it might be a missconfiguration of the person. But since it loads, but slowly, the problem must be somewhere else. Don't think that this is a problem of persons here.
    Correct. Since it happened in Spain in high season we assume, that it was due to voltage fluctuations in the power grid. This may happen in areas which have in high season 5-10 times more people than inhabitants.
    P.S. edit
    Not to say that the Swiss importer must sell the OP3 with a normal adapter. So there must be something tricky with the dash charger technique.
    #57
    ChinChinati likes this.
  18. Sushma91 Cupcake Oct 19, 2016
    Sushma91, Oct 19, 2016 :
    Am also facing the same prob.
    My oneplus 3 has totally stopped dash charging. Can anyone help me in this ?
    Is this a software bug or any type of settings to be changed ?
    #58
  19. Priyansh18 Cupcake Oct 22, 2016
    Priyansh18, Oct 22, 2016 :
    Tried doing this too.. I received my device after service yesterday only.. And now I have to visit service centre again due to this problem..
    #59
  20. Ahmad Jribi Eclair Nov 2, 2016
    Ahmad Jribi, Nov 2, 2016 :
    same here guys i puted my op3 charging , it did well in 30 mins it went from from 20% to 83% (10% in 4mins frequency) but then it started slowing down.. it did the other 20% in another 30mins no idea why...
    #60
