7
Battery/Charging
Why dash charging sometimes is not working?
  1. JeyNessuno Cupcake Nov 6, 2016
    #61
  2. Spelt Ice Cream Sandwich Nov 6, 2016
    Spelt, Nov 6, 2016 :
    It will get warm but not hot. Other charging systems on other phones can make them get hot.
    #62
  3. Spelt Ice Cream Sandwich Nov 6, 2016
    You can use any other USB car charger with the same cable but you won't get Dash charge speeds. That is only available with Dash chargers.
    #63
  4. deadesideria Cupcake Nov 30, 2016
    deadesideria, Nov 30, 2016 :
    I got a problem, my battery stayed in 50%. I charged it for hours and the status of the battery is not charged, even I plug in the charger. it is said that the battery is too low and the temperature is too low.. can anyone help me?
    #64
  5. lijuvj19 Cupcake Dec 23, 2016
    lijuvj19, Dec 23, 2016 :
    I got my 3T three days back and now dash charger stopped working..gng to replace it under warranty
    #65
  6. G_Filipe_Gonçalves_crAd Donut Jan 9, 2017
    G_Filipe_Gonçalves_crAd, Jan 9, 2017 :
    Started having this problem recently... have to unplug and plug a couple of times to get dash to work... maybe some problem with the cable from wear...?
    #66
  7. cssoz Honeycomb Jan 10, 2017
    cssoz, Jan 10, 2017 :
    ya not sure but it will work again when you unplug the cable from the adapter and push it back in all the way. been like this since day 1
    #67
  8. mzkaye729 Cupcake Jan 10, 2017
    mzkaye729, Jan 10, 2017 :
    Kind of weird but we've been having really cold temperature here in Toronto (literally in the minus) and I noticed if the phone gets too cold, it won't dash charge.
    Once it's warmed up and in room temperature, it starts to dash charge. But if I'm coming from outside with the phone in my pocket for an extended period of time in the cold, I notice the issue pop up.
    #68
  9. cssoz Honeycomb Jan 10, 2017
    interesting. well i always dash charge in a room =P not outside. Toronto too here
    #69
  10. Regd Eclair Jan 19, 2017
    Regd, Jan 19, 2017 :
    I have the same problem here :\. Sometimes when I plug my OP3 with the dash charge, it charges in normal mode instead of dash mode, and that way it takes ages to charge :(. Is there a solution for this problem?
    #70
    luis_moreira likes this.
  11. Sayyad Irfan Ahmad Cupcake Jan 25, 2017
    Sayyad Irfan Ahmad, Jan 25, 2017 :
    My dash charger is not working. Start charging from 15℅ with dash charger, it has taken more than an hour. Please guide..
    #71
  12. Zh_kilat Android Q Jan 25, 2017
    Zh_kilat, Jan 25, 2017 :
    No problem so far when running oos roms..... had the issue occasionally on custom roms before, needed to restart the phone and/or flip the type c
    #72
  13. G_Ramamohan_Raju_IZZI Cupcake Jun 3, 2017
    G_Ramamohan_Raju_IZZI, Jun 3, 2017 :
    I have this problem from past few days. Its been 1 year that I bought it but the problem is there from past few days only. Dash charge is not happening only when the phone heat is more than usual.
    #73
  14. BikerMom Honeycomb Jun 3, 2017
    BikerMom, Jun 3, 2017 :
    I think you just cracked the case...! :p
    #74
  15. ButcherChop Cupcake Sep 12, 2017
    ButcherChop, Sep 12, 2017 :
    Yep.
    I have a OnePlus3.
    I have a OnePlus 3 dash charger.
    I have a OnePlus 5 dash charger.
    Neither work consistently on my OnePlus3, but work fine on my OP5. The notification light will go from red to blue, back to red and then blue again. Then i'll try another time and i'll be lucky and it will dash charge. It used to have an 80% success rate, but now it hardly ever works.
    It charges fine with my Anker brand products, just no Dash charge.
    Thankfully the phone is still under warranty, but i have to pay for shipping and wait for who knows how long to get it back.
    #75
  16. G_Vgh Cupcake Sep 22, 2017
    G_Vgh, Sep 22, 2017 :
    Hi, i just had this issue a couple days ago, and after some research i found that you actually could go into the Service Testing panel by composing *#808# using the "calling" application .. after hitting the battery test, dash charge came back with no reason ... hopefully it's a long time fix and i won't be disappointed tomorrow.
    Hopefully it'll save some of you ;)
    #76
  17. cssoz Honeycomb Sep 25, 2017
    cssoz, Sep 25, 2017 :
    I have had the 1+3 which is now my fathers.
    Solution for normal mode instead of DC for 3/3T: Unplug the cable from the AC brick. push it all the way in. Fixed
    #77
  18. Cyanidebreathmint Ice Cream Sandwich Sep 25, 2017
    Cyanidebreathmint, Sep 25, 2017 :
    Buy a DC inverter for yr car. 30W inverter would be sufficient and may be less expensive than the dash car charger.
    #78
  19. pravinxp Cupcake Nov 2, 2017
    pravinxp, Nov 2, 2017 :
    I am using Oneplus 3, and Dash charging stopped working after the last update. I am using original charger and cable from Oneplus. Any solutions for the same?
    #79
  20. pravinxp Cupcake Nov 2, 2017
    Solved, USB in the brick not pushed all the way in :D
    #80
