7
Battery/Charging
Why dash charging sometimes is not working?
  1. gbyrne Eclair Jan 14, 2018
    gbyrne, Jan 14, 2018 :
    Just an update for anyone googling the issue. The power slot is a lint magnet get a really thin needle or pin to get the what's bound to be now compressed lint out if the slot. The dash cable then seated correctly and I get dash charge again. Was also an issue for Android auto not working on the same cable.
    #81
    ch.naveed.akbar likes this.
  2. Y1515755242126 Cupcake Jan 28, 2018
    Y1515755242126, Jan 28, 2018 :
    I too have the same problem.I am using the same adapter and same cable provided by one plus and also using the same socket maximum times.Some times it dash charging and most of the times normal.
    i dont know WTF is this with one plus 5t.Many problems.
    #82
  3. ShiroShadow Gingerbread Mar 24, 2018
    ShiroShadow, Mar 24, 2018 :
    LoL. I had the same issue today. Phone wasn't dash charging. So I pushed the Usb side of the cable a bit hard into the OEM brick. Problem solved. Phone is now dash charging.
    #83
  4. Robson_DeluXeXBR Eclair Jul 10, 2018
    #84
  5. nbarry Froyo Jul 10, 2018
    nbarry, Jul 10, 2018 :
    try plugging it directly to the wall and see if it makes a difference
    #85
  6. Robson_DeluXeXBR Eclair Jul 11, 2018
    Robson_DeluXeXBR, Jul 11, 2018 :
    Didn't work. I noticed that my computer didn't recognize the oneplus anymore (the notification menu to choose the type of conection, charging or mtp) and neither OTG function. I think the problem is the type c conector or the flex cable. I will try to replace.
    #86
  7. Koss Rares Cupcake Jun 21, 2019
    Koss Rares, Jun 21, 2019 :
    Good morning guys. Ia came with a similar problem. I have my OP3 And i just get a brand new dash charger 2 days ago. Strat to charge normally till 80% then dash charge stop every 15 seconds and start again. Is doing this thing till 90% and then strat to work normally again till 100%. I noticed this problem only now after last update.
    #87
