WHY DOES IT TAKE SO LONG TO CONNECT TO WIFI??
  1. invincible64
    Ice Cream Sandwich Nov 15, 2014
    invincible64 , Nov 15, 2014 :
    I turn it on, and it takes like a minute to connect, compared to my ipod touch which literally takes 2 seconds. Its not just the latest update, its been like this since I got the phone in August. Is there a fix for this, or even an explanation?
    ronoldo likes this.
  2. missy.wyman
    Honeycomb Nov 15, 2014
    missy.wyman , Nov 15, 2014 :
    I have no problems with my opo connecting to wifi quickly
    ronoldo likes this.
  3. ronoldo
    KitKat Nov 15, 2014
    ronoldo , Nov 15, 2014 :
    Haven't had that problem... perhaps it's the router... but someone else might have a better answer..
    Boricua and eckbauer like this.
  4. punith
    punith , Nov 15, 2014 :
    check how many are in the same channel, try changing your wifi channel
    macem29 likes this.
  5. Casper5555
    Gingerbread Nov 15, 2014
    Casper5555 , Nov 15, 2014 :
    Have had no problems at all, other than having to connect again, it seems to cut off after a while...
  6. xf4d3
    xf4d3 , Nov 15, 2014 :
    cos you are using caps??
  7. mmc77
    mmc77 , Nov 15, 2014 :
    Mine is slow also, lte /4G connects in one sec but WiFi takes problem 30 to 4G sec. Every other device I have connects to WiFi straight away. Not a big drama but it does happen
  8. Joyyy
    Jelly Bean Nov 15, 2014
  9. Cobrin
    Cobrin , Nov 15, 2014 :
    DL wifi analyzer and scan your area and see who else is on the same ch
    Go into advanced wifi settings on your opo and check it's settings turn off wifi optimisations.
  10. ageorgiou
    Ice Cream Sandwich Nov 16, 2014
    ageorgiou , Nov 16, 2014 :
    This happens to me too but only on certain routers. I am connected to wi fi and pages load slowly or don't load and I get an error that I'm offline when I am connected to wi fi. I have to reboot my phone to reconnect to the Internet. I find this only happens with certain routers.
  11. Cojy
    Gingerbread Nov 16, 2014
    Cojy , Nov 16, 2014 :
    This bug is known and was supposed to be fixed by 44s, but it is still present. Be patient, maybe someday it will be fixed.
    Garywehrle likes this.
  12. Cobrin
    Cobrin , Nov 16, 2014 :
    I haven't a problem with mine at multiple access points across friends/family/public wifi. Guess I'm one of the lucky ones.
  13. 4nlimited3dition
    Jelly Bean Nov 16, 2014
    4nlimited3dition , Nov 16, 2014 :
    I noticed that my OPO doesn't instantly automatically search for wifi devices so I always press the search button, it's way faster.
    sh3llshock likes this.
  14. iamsndn
    Cupcake Nov 16, 2014
  15. sh3llshock
    KitKat Nov 16, 2014
  16. OPOALEX50
    Eclair Dec 19, 2014
    OPOALEX50 , Dec 19, 2014 :
    Mine takes about 10 seconds. Whereas my tablet takes about 3 seconds to connect. It's not that bad but it still worries me a little. Is it a software issue? Has it been fixed?
  17. TakeMyMoney
    KitKat Dec 19, 2014
  18. ain.hoss07
    Gingerbread Dec 19, 2014
    ain.hoss07 , Dec 19, 2014 :
    Try hard reset? If that doesn't work, try flashing the new CM12 and see if it works?
  19. MagicTwat
  20. Domoxrage
    Cupcake Dec 19, 2014
