Why does oneplus recommend we only use their charger?
  1. Joel B
    Honeycomb Aug 28, 2014
    Joel B , Aug 28, 2014 :
    I admit that I don't know that much about tech so I was wondering what's so special about their charger that they don't recommend that we use any other charger then their own. Aren't most usb chargers the same? (I know the Oppo a1 has fast charging so that might not be compatible)
    Edit: its been answered in the comments, thank you all!
  2. maurini
    Nougat Aug 28, 2014
    Takendown, soufiane, raimondl and 3 others like this.
  3. DannY09
    Eclair Aug 28, 2014
    GoldenBoyRB likes this.
  4. Fetterfly
    Gingerbread Aug 28, 2014
    Fetterfly , Aug 28, 2014 :
    No idea but what I did notice is it appeared to charge quite quickly (or at least to me).
  5. UnknownSoul
    Jelly Bean Aug 28, 2014
    Benjanz, jkbhso3, GuyWithHat and 3 others like this.
  6. LostPorcupine
    KitKat Aug 28, 2014
    LostPorcupine , Aug 28, 2014 :
    Probably because most tankard chargers only put out about health power, and factoring in phone power usage would probably take up to 4 hours to charge.
  7. sri072
    sri072 , Aug 28, 2014 :
    I think all the companies do this to make people avoid using some cheap cables
  8. NightlyCoder
    Eclair Aug 28, 2014
    NightlyCoder , Aug 28, 2014 :
    I'm playing Ingress and a battery pack is required sometimes.
    I hope warranty is not affected, when using battery packs :eek:
    GarryTheOgre likes this.
  9. krucymucy
    krucymucy , Aug 28, 2014 :
    If you use a more powerful charger you risk the damage of the battery and phone.
    OPO's charger has 2A output, I would even recommend less than that.
    There are chargers available with higher current output, they charge the phone quicker, but at the cost of damaging your battery.
    Thanks, but no thanks.
    Takendown, Benjanz, ninfrank and 2 others like this.
  10. Iseek1
    KitKat Aug 28, 2014
    Iseek1 , Aug 28, 2014 :
    Uhm, simply cuz they designed / built it for their phone, so they "matched" it to the spec they knew was required and there are so many different spec'd chargers that they didn't have the time / didn't even want to go through them all and give each a pass / fail spec wise.
  11. mmediadev
  12. Iseek1
    KitKat Aug 28, 2014
    Well, that's not exactly correct, you should take a look at this;
    Charge your smartphone 92% faster by PLX Devices
    http://www.plxdevices.com/product_info.php?id=MOBLLEGIONMETER
    smaug42 and acruxksa like this.
  13. Iseek1
    KitKat Aug 28, 2014
    and it's not the battery so much as it is the support circuitry around it for the power handling and charging
  14. pspinto
    Ice Cream Sandwich Aug 28, 2014
    pspinto , Aug 28, 2014 :
    As long as you keep the current within 2A (or less), you won't damage your OPO!
    Mattster and Joel B like this.
  15. gusuraman
    Community Veteran Aug 28, 2014
    gusuraman , Aug 28, 2014 :
    I'm using a Samsung charger 2.1Ah with HTC cable. I don't notice anything wrong.
    As soon the power supply is stable direct current with correct voltage (as for standard USB) with enough amperage, there is no reason to discriminate brands.
    Of course a 1€ charger should be avoided.
  16. krucymucy
  17. Iseek1
    KitKat Aug 28, 2014
    Nishen, Mattster and krucymucy like this.
  18. Android the Greek
  19. krucymucy
    No, it's the battery...
    Here's the photo of a battery from samsung S4 which was left on charger for a month ...
  20. sgrinavi
    sgrinavi , Aug 28, 2014 :
    The first rule of the one plus one club is we don't talk about the one plus one club
    Now go back to your charging
