OxygenOS
Why is half my battery icon disappeared???
What is this??
  1. BUG
  2. FEATURE
Results are only viewable after voting.
  1. Emmeemme98 Cupcake Mar 9, 2019
    Emmeemme98, Mar 9, 2019 :
    I've noticed that icons associated with battery tend to disappear partially if the notch is hidden on a white background, it works fine with dark/colored background application.
  2. LegolasX Jelly Bean Mar 10, 2019
  3. Emmeemme98 Cupcake Mar 10, 2019
    Emmeemme98, Mar 10, 2019 :
    1) with the notch hidden it's always black up there so why does it need to change for half the apps? there's no point in blending in for only some of them.
    2) if you look at the Bluetooth icon where it shows the battery of my Bluetooth headphones (red) the whole Bluetooth symbol is disappeared even if they are still connected and showing their battery.
  4. LegolasX Jelly Bean Mar 10, 2019
    LegolasX, Mar 10, 2019 :
    Many apps control status bar and nav bar color, thus they have different background color on those.
  5. Emmeemme98 Cupcake Mar 10, 2019
    it changes color but it's never black and also the other half of the battery is always there...
  6. Cloverfields Cupcake Mar 10, 2019
  7. Emmeemme98 Cupcake Mar 10, 2019
    yes it still does it
