Why my Audio in Pubg & Bluetooth Headphone is Like Phone Speaker
  1. BYG BYRD
    Honeycomb Sep 28, 2018
    BYG BYRD , Sep 28, 2018 :
    After the update this Problem has Wasted my Skull Candy Crushers.
    I can't use them wireless because there is a lag of 1 sec of voice and SFX also heard late.
    Can You Fix it.
    I have my Pubg Unofficial UG Match 5 days Later
    See in Volume there is Phone Speaker Sign Not Media Sign.
  2. M1509175578422
    Cupcake Sep 29, 2018
  3. rohith.srivastav
    Honeycomb Sep 29, 2018
    rohith.srivastav , Sep 29, 2018 :
    its because you have turned your microphone on and it works like a walkie-talkie between you and your teammates
    Sargo likes this.
  4. G_syed_saad_cSVb
    Donut Mar 22, 2019
    G_syed_saad_cSVb , Mar 22, 2019 :
    bro do you use 6t?
  5. Kytharsis
    Marshmallow Mar 23, 2019
    Kytharsis , Mar 23, 2019 :
    This thread is from September...
    xnutzii and Deactivated User like this.
  6. Deactivated User
    Mar 23, 2019
    Deactivated User , Mar 23, 2019 :
    No one ever accused the posters here of being too quick. ;)
    Kytharsis, xnutzii and Neddard like this.
  7. rohith.srivastav
    Honeycomb Mar 28, 2019
  8. G_syed_saad_cSVb
    Donut Mar 28, 2019
  9. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Mar 28, 2019
    KeepTransisting , Mar 28, 2019 :
    You're going to get lag on bluetooth audio when gaming no matter what. It's just a limitation of the technology at the moment.
  10. E1553405816799
    Cupcake Mar 29, 2019
    E1553405816799 , Mar 29, 2019 :
    I play it on mine when I'm not playing on my iPad. max video without any issues. but I use a wired headset.
  11. G_syed_saad_cSVb
    Donut Mar 29, 2019
    G_syed_saad_cSVb , Mar 29, 2019 :
    when you play pubg on ur 6T USING A WIRED EARPHONES, how are you able to hear the enemy footsteps while they are near you, I mean the other day I played it on a phone with 3.5mm Jack in it and the experience was so different! I was able to hear the enemy if he was on my left in my left earphone and if he was on my right the right side earphone! this is not happening in my 6t when like connect the 3.5mm earphones with the 3.5mm usb type c connector! please reply back
  12. E1553405816799
    mine works perfectly. I use the adapter dongle and a set of Triton gaming headphones. While I'm spectating I can usually hear the enemies and their direction way before and better then my teammates.
  13. G_syed_saad_cSVb
    Donut Mar 29, 2019
    but how? I use apples earpods which come in apple boxes with phones! I can't hear when I connect then to my 6t using the USB type c connector, I used the same phone in my friends redmi note 7 pro and I could here so much sound and pin point enemy Location so well! we can't do the same with my 6t I hear foot steps sound in both my ears! I event used a Sony mdr-xb450 headsets using the USB type c connector no use[e]1f494[/e]
  14. E1553405816799
    well I would suggest having them looked at then. something isn't right. mine are perfect using the jack.
  15. G_syed_saad_cSVb
    Donut Mar 29, 2019
    with the jack? you mean to say with the USB type c connector Wich came with the one plus 6t?
  16. E1553405816799
    yes...
  17. G_syed_saad_cSVb
    Donut Mar 29, 2019
    bro can we chat on Instagram? are you on insta? add me please it's a bug issue I wanna talk about it more? @saad_hussainn my insta handle
  18. E1553405816799
    I'm not diagnosing your phone for you over a chat... Either your headset is junk or your port or dongle is messed up. bring it to a store or phone repair place and have it looked at
    G_syed_saad_cSVb likes this.
  19. G_syed_saad_cSVb
    Donut Mar 29, 2019
    thanks
  20. Jogi5
    Ice Cream Sandwich Mar 29, 2019
