why no in display fingerprint scanner to op6
  1. F1527093299085 Cupcake May 25, 2018
  2. rwmchan Jelly Bean May 25, 2018
  3. G_Ananthu_Mohan_lnGt Eclair May 25, 2018
    G_Ananthu_Mohan_lnGt, May 25, 2018 :
    I think because the tech is in it's developing stage ,as most of u guys have seen the indisplay fingerprint reader is not as fast as the on body fingerprint reader.Being a flagship they will incorporate features only which are the best.The op6 sloagan being "the speed you need" .
    rahuldw181 likes this.
  4. rahuldw181 Ice Cream Sandwich May 25, 2018
  5. BobbyV8_ The Showcase Reviewer May 25, 2018
    BobbyV8_, May 25, 2018 :
    So you don't really care about the SOC used?
    Vivo you are pointing at is running sd660. OP6 runs on sd 845
    2 year old sd 821 is far better than sd 660 and you feel no difference comparing them!?
  6. rahuldw181 Ice Cream Sandwich May 25, 2018
    rahuldw181, May 25, 2018 :
    agree
  7. Digita1Err0r Gingerbread May 25, 2018
    Digita1Err0r, May 25, 2018 :
    it's definitely not about the cost! in-display fingerprint sensor at its current age is a serious downgrade to a physically present fingerprint sensor.
  8. BobbyV8_ The Showcase Reviewer May 25, 2018
    So you should stop saying it repeatedly. Vivo is kind of testing the tech. You can't rant for a half baked product. Doesn't make sense.
    Rahul was repeatedly pointing out atthe cost. So i had to tell him the difference. TBH in display fingerprint sensor is still half baked and needs improvement, so the company can try to give it out at lesser cost, not an issue.
  9. rahuldw181 Ice Cream Sandwich May 25, 2018
    ok boss
