Why One Plus X has 16 Gb of internal Memory
  1. vigneshwar33
    Cupcake Oct 29, 2015
    vigneshwar33 , Oct 29, 2015 :
    What you don't understand ? Yes I know its not possible to edit the title ,we do make typo's .
    If you feel about the grammatical correctness ,pls rephrase it .
  2. ambivertguy
    Gingerbread Oct 29, 2015
    ambivertguy , Oct 29, 2015 :
    You do have a point. Though it might be a very slight problem now (some apps only get installed on the internal storage) and a Marshmallow update could fix it to a great extent or even completely, the point you seem to be missing is that it might take forever to get a Marshmallow update.
  3. neisor
    neisor , Oct 29, 2015 :
    I would suppose it's because the OnePlus X is the mid-rangephone with a price acknowledging just that fact. So, since you can expand your memory via MicroSD card, you can still save some money by a lower inbuild memory. They wanted to aim at a lower price, so they made it even by compromising the inbuild memory, which, in my opinion is a good choice. Remember, that they could sacrifice CPU or RAM for the price, and they did not do that. So, think about it :)
    God bless you.
    vigneshwar33 likes this.
  4. vigneshwar33
    I had dreadful experience with memory card .Memory cards have certain read and write cycles and the performance will be drastically diminished over the time.
  5. byno
    Ice Cream Sandwich Oct 29, 2015
    byno , Oct 29, 2015 :
    Very true, I'm guessing though that OnePlus made this phone 16GB internal with 6.0 firmly in mind. It's not ideal but it'll all boil down to cost cutting.
    Unfortunately though if people need a dual sim phone and more than 16GB then this isn't going to be the phone for them.
    vigneshwar33 and ambivertguy like this.
  6. ambivertguy
    Could be that. But I think it's mostly cost cutting. Reduce the internal memory and provide an SD card slot. Voila! Phone cost goes down. (Maybe by a little or by much. Not important.)
    Personally, I don't think it would be as huge a problem as people here are projecting it to be (Just look at the number of damn threads complaining about memory!) Keeping everything on an SD card also makes it easier to move most of your data.
    There is no perfect phone. You have to give up on something to get something and OPX seems to be a fair deal considering everything it has and doesn't.
  7. alfonso.lopez08
    Honeycomb Oct 29, 2015
    alfonso.lopez08 , Oct 29, 2015 :
    Crystal Clear here
  8. veratoloz2005
    Lollipop Oct 29, 2015
    veratoloz2005 , Oct 29, 2015 :
    I am not concerned about memory. Reception in the USA will be subpar, as bands 12 and 17 are not supported by X.
  9. sXe
    sXe , Oct 29, 2015 :
    Missing band 17 is huge for Att people, but no band 12 for tmobile shouldn't be too bad. I had a Note 3 on tmobile and it didn't have band 12 at all, and it worked fine. It will be like tmobile reception 2 years ago. Sucks they didn't add it, but I think it won't be horrible.
  10. veratoloz2005
    I am with ATT.:)
    sXe likes this.
  11. sXe
    Yeah then I'm with you on that. ;)
    veratoloz2005 likes this.
  12. jaycob619
    jaycob619 , Oct 29, 2015 :
    No I'm just having to use a second phone for work related stuff atm
    I thought their saying was "Never settle" or do they not take that seriously?
  13. killing.devil
    killing.devil , Oct 29, 2015 :
    There is no perfect smartphone and never will be..and i hope you know that...you need to settle for some reasons...
    If i get a s6/edge i need to settle for less battery, if i get an iphone 6 i need to settle for less customizability... If i get a note 5 i need to settle for a non - removable battery and storage expansion...and bringing a single sim "dual sim with compromises", what is the harm...most flagships are single sim devices ...and being a single sim device doesn't mean you settle for something....be honest and tell me
    If you get a s6/note5 / iphone 6s/lg g4 /nexus 6p for this price ...wouldn't you take it and settle for a single sim device...
    Please think about it
    The7God likes this.
  14. billy_boolean
    Jelly Bean Oct 29, 2015
  15. The7God
    The7God , Oct 29, 2015 :
    I believe that they are cutting costs by having an inbuilt memory of 16gb, which allows it to be cheaper and more affordable for the public.
    vigneshwar33 and killing.devil like this.
  16. mwayner
    mwayner , Oct 29, 2015 :
    Well, it's not being marketed as a flagship. You'd be hard pressed to fill up 16GB of internal memory with apps that need to perform very quickly. What the OPX has is the luxury of additional onboard memory for data storage, well beyond that of the flagships. Ironic, ain't it?
    ambivertguy likes this.
  17. Deactivated User
    Oct 29, 2015
  18. mwayner
    There's a promised 32GB OPX variant?:eek:
    #38
  19. Deactivated User
    Oct 29, 2015
    #39
  20. ratification
    #40
