Why oneplus 7 pro has corning gorilla glass 5 instead of 6
  1. Siddharth P.A
    Gingerbread May 19, 2019
    Siddharth P.A , May 19, 2019 :
    My friend accidentally broke his OP 7 screen, the distance of the ground was 1 meter, nevertheless screen shattered
    W1577107808650 likes this.
  2. meatandy
    Oreo May 19, 2019
  3. Siddharth P.A
    I've asus zenfone max pro m1 with Corning gorilla glass 5 the same which op7 pro has..
    Everyday I dropped my phone accidentally at least 1 time still it has no scratch
  4. Prowller
    Prowller , May 19, 2019 :
    OP 7 Pro has gorilla glass 5 on the back and 6 on the front(display) but it's resistent to scratches not durable to cement impacts. It depends on how the phone fell because some spots on the display or back make just a small crack while other spots shatter it completely.
    O1574194062837, Salt505 and mkhare like this.
  5. Budruel
    KitKat May 19, 2019
    Budruel , May 19, 2019 :
    Congratulations, I'm sure he's the first one!
  6. Neddard
    Lollipop May 19, 2019
    Neddard , May 19, 2019 :
    "at least 1 time, everyday I dropped my phone"
    Seriously?
    I haven't dropped a phone, accidentally or otherwise, in 10 years. Maybe longer.
  7. Jjallday
    Jjallday , May 19, 2019 :
    there is always that person that has a friend that did something smh..show pictures or it never happened.
    O1574194062837 and Budruel like this.
  8. VaguelyWoo
  9. meatandy
    Oreo May 19, 2019
    meatandy , May 19, 2019 :
    Seems you and your friend are both clumsy.
    Let's see a picture of your friends shattered dreams.
  10. annmey
    Cupcake May 20, 2019
    annmey , May 20, 2019 :
    I think I've dropped my OP3 at least 100 times. Had to sent it in for repair once but otherwise it's a pretty durable phone. Really afraid to use the 7pro..
    I don't know how people can do this. I've dropped my OP3 not every day but I'd say at least 100 times (had to send it in for repair once, but otherwise it's pretty durable).
  11. Y1558842614135
    Cupcake May 26, 2019
    Y1558842614135 , May 26, 2019 :
    Well i drop my op7 pro higher than 1meter and nothing happened
    O1574194062837 likes this.
  12. Loveit
    KitKat May 26, 2019
    Loveit , May 26, 2019 :
    I'd say I drop my phone around once every month. It's actually quite enjoyable when it happens when you know it's properly protected (TGSP and Spigen Slim Armour).
    I replaced my case the other week it was pretty battered from a year's worth of protection.
  13. bpwest80
    KitKat May 26, 2019
    bpwest80 , May 26, 2019 :
    I drop my phones sometimes but it's rare. I've cracked screens before so I take precautions with a case and screen protector.
  14. robert3892
    Honeycomb May 26, 2019
    robert3892 , May 26, 2019 :
    If your OnePlus 7 Pro falls onto cement with the glass front hitting first it is likely to break unless you have additional coverage on the device such as a tempered glass screen protector and also a drop resistant case. Even with these items applied breakage is still possible, but at a reduced risk.
    O1574194062837 and Siddharth P.A like this.
  15. F_Niall_Love_bRvB
    Froyo May 30, 2019
  16. tekknikal
    Eclair Jun 4, 2019
    tekknikal , Jun 4, 2019 :
    According to Corning's own page, op7 pro has gg5 on both the front and the back.
    You actually might be surprised to find that the newer versions of gorilla glass actually sacrifice scratch protection for better drop protection. The way it works, they can't have it both ways.
    Personally I think it's unfortunate... I'd rather have a device that is relatively scratch proof. Glass is glass, and it's going to break, but older phones I've had have held up far better to scratches than any of my devices with gg5 on them.
    "The main way that glass makers strengthen glass is through tempering, which can either be an intense heating process or a chemical treatment, like a salt bath. As Caltech professor of materials science William L. Johnson explains, the internal stress causes the glass to yield more easily to any introduced stress on its surface. In simple terms, that means when the glass is more tempered, it often scratches more easily."
    Tests that Verge performed seem to indicate that GG3 was the most scratch resistant of the bunch. Corning doesn't acknowledge this directly, but they do admit that they have prioritized drops over scratching in the past few iterations.
  17. Siddharth P.A
    Gingerbread Jun 4, 2019
    Siddharth P.A , Jun 4, 2019 :
    that means gg5 is better in drop protection instead of scratch protection?
  18. tekknikal
    Eclair Jun 4, 2019
    Yes, that is correct. It appears that it goes something like this...
    Scratch: GG3>GG5=GG6>GG4
    Drop: GG6>GG5>GG4>GG3
    I'm not sure about anything before GG3.
    K_Hunter likes this.
  19. Vastator
    Cupcake Jun 4, 2019
    Vastator , Jun 4, 2019 :
    Strange is that normal OnePlus 7 (without "Pro") Has 6th CGG on front...
    And no, IT is not a problem with curved glass cuz Samsung s10+ Has curved with CGG 6.
  20. tekknikal
    Eclair Jun 4, 2019
    Yeah, that is odd. I figure it is either a supply issue or more likely it cost more to get gorilla glass for the curved display vs flat/2.5d. It could even be as simple as the rest of the op7 pro was closer to cutting in to profit margins where the op7's frugal design might have had more wiggle room.
