Why oneplus has not yet fixed the wifi (4.5.8)
  1. akunh121
    Gingerbread Aug 5, 2017
    akunh121 , Aug 5, 2017 :
    The wifi dont disconnecting
    The wifi every 10-20 Minutes stop working
    I fix it with turn off and on the wifi
    #41
    Arjit Sawhney likes this.
  2. malidan
    Nougat Aug 5, 2017
    malidan , Aug 5, 2017 :
    That is not a fix:confused:
    Its your device and your decision but I would have sent it back before the 15 days was up.
    And if I had it now, I would be speaking to PayPal, no matter which way you cut it you have a defective device
    #42
  3. akunh121
    I'll wait for the next update
    #43
  4. Uncle timmy
    Uncle timmy , Aug 5, 2017 :
    Don't wait. As much as I have different views as @malidan he really does seem to be correct in this case. If nothing is resolving your issue then it most likely is hardware and if it's not you cannot be guaranteed oneplus will be fixing your issue with a software update.
    #44
  5. F_Jiten_Kumar_Pal_JlcJ
    Donut Aug 5, 2017
    #45
  6. malidan
    Nougat Aug 5, 2017
    You may want to read through the
    3T
    3
    X
    2
    Support sections and see what the future holds for you, there are people even now still having this type of issue.
    You will come to learn one thing about this forum, don't rely on what other owners say when its come to your own device.
    At times it seem like people will put up with anything to own a OP device, for what reason I don't know.
    #46
  7. rbparagi
    Cupcake Aug 5, 2017
    #47
  8. akunh121
    I got 4.5.8 a few days ago
    #48
  9. akunh121
    I am not the only one with this problem
    https://forums.oneplus.net/threads/wifi-issue-with-oneplus-5.555048/
    https://forums.oneplus.net/threads/issues-with-4g-network-wifi.575034/
    #49
  10. Uncle timmy
    #50
  11. malidan
    Nougat Aug 5, 2017
    As I said bro, don't rely on what other owners say when it comes to your device.
    People will say wait for a software update, but if you look through OP's device history the issue is still prevalent.
    Look after no.1 like OP does, the WiFi dropping ever 15-20 min. is unacceptable even at $50.
    #51
  12. akunh121
    I can not be without a phone
    I tried with smart wifi on and off and it not fix the problem
    #52
  13. akunh121
    #53
  14. Uncle timmy
    Have you tried using someone else's wifi with the same results?
    #54
  15. gopi1410
    Froyo Aug 5, 2017
    gopi1410 , Aug 5, 2017 :
    I do not have this issue but face game stutters frequently post the update
    #55
  16. akunh121
    I tried only with my wifi
    but it does not matter
    on my nexus 5 is working good
    #56
  17. Uncle timmy
    If you try with a different wifi network and it works then you narrow down what's causing the issue. I get you have a different phone to use, but you should not be deficient with the op5.
    #57
  18. royalemint
    #58
  19. akunh121
    I will try a different wifi
    My nexus 5 I gave to my brother
    I try reset factory settings
    #59
  20. HuzefaKagal
    Froyo Aug 5, 2017
    HuzefaKagal , Aug 5, 2017 :
    Try resetting your router, or else change from a 5 GHz to 2.4 GHz band. I'm on a 2.4 GHz band on my router and have OOS 4.5.8, no issues.
    #60
