9
Why system block a massive storage? via OnePlus 8T Lunar Silver
  1. #1
    U6361581022, Toschi23, 1+noor and 6 others like this.
  2. TheMystic
    Lollipop Apr 19, 2021
    TheMystic , Apr 19, 2021 :
    You have probably enabled logs.
    There is a way to disable it. I forgot the exact code sequence, but you can search for it in the forum.
    For now, find the OnePlus folder in internal storage and delete it.
    O1614621808919 and dikoscilator like this.
  3. Tarun.
    Froyo Apr 20, 2021
    O1614621808919 likes this.
  4. Bobbie63
    Nougat Apr 20, 2021
    Bobbie63 , Apr 20, 2021 :
    *#800#, this will enter the log kit, turn off anything in here that's turned on, and tap the bin to clear all existing oem_logs.
  5. O1614621808919
    Froyo Apr 20, 2021
    O1614621808919 , via OnePlus 8T , Apr 20, 2021 :
    But it's not work
  6. Bobbie63
    Nougat Apr 20, 2021
    What does it say? Was anything turned on?
    Tokolozi likes this.
  7. O1614621808919
    Froyo Apr 20, 2021
  8. O1614621808919
    Froyo Apr 20, 2021
  9. Bobbie63
    Nougat Apr 20, 2021
    Ah ok, could you Check in the file explorer if there is anything in a folder named oem_log?
  10. O1614621808919
    Froyo Apr 20, 2021
  11. Bobbie63
    Nougat Apr 20, 2021
    What if you check for large life’s in the file manager, anything real large in there?
    O1614621808919 and Tokolozi like this.
  12. O1614621808919
    Froyo Apr 20, 2021
  13. Bobbie63
    Nougat Apr 20, 2021
    I really don’t understand where all that storage went. They to clear cache in recovery, maybe that will solve it, I’m a bit out of options for the rest tbh
  14. Bobbie63
    Nougat Apr 20, 2021
    I was just thinking, did you ever got some message that you were low on storage?
    you want to clear the cache of the file manager first and see if that changes anything and reboot
  15. abidbunny
    Ice Cream Sandwich Apr 20, 2021
    abidbunny , via OnePlus 8T , Apr 20, 2021 :
    Open file manager>3 dots(right upper corner)> settings>show hidden files turn it on then head to the internal storage portion and delete all folders starts with . And if you find any folder which not belongs to you like logs,ota etc etc delete them all.
    If it won't work try resetting your phone.
    If it won't work try hard reset (switch off your phone then press and hold volume up+power button and then wipe data)
    If it won't work visit nearest service center, it definitely works. said:
    ps: backup your data before reset.
  16. O1614621808919
    Froyo Apr 21, 2021
    O1614621808919 , via OnePlus 8T , Apr 21, 2021 :
    I have done this, lots of times
  17. O1614621808919
    Froyo Apr 21, 2021
    It's not work (Hard reset). I have done this lots of times. I bought it from Bangladesh and I also living in Bangladesh. The main problem is, hare is no servicing center of oneplus.
    Bobbie63 likes this.
  18. Bobbie63
    Nougat Apr 21, 2021
  19. O1614621808919
    Froyo Apr 21, 2021
  20. Bobbie63
    Nougat Apr 21, 2021
    Bobbie63 , Apr 21, 2021 :
    Yes, sorry we couldn’t figure out how to solve this, hope you get your issue sorted soon.
