[Submitted] Wi-Fi Roaming not working when Disaplay is not active
  1. S1615720227926
    Cupcake Sep 11, 2021
    S1615720227926 , Sep 11, 2021 :
    Perform wifi-roaming from ap to another ap while the display is turned off. if you roam with turned off display, wifi symbol has an (!) behind and wifi states to have no internet connection. you cannot ping the device any more.
    works fine when roaming happens, while display is activated.
    Details: https://www.wlan-blog.com/erfahrungen/wlan-roaming-problem-mit-oneplus-6-und-android-11-oxygenos-11/
  2. Ankita_S.
    OnePlus Bug Hunter Staff Member Sep 11, 2021
    Ankita_S. , Sep 11, 2021 :
    For analyzing this better we would need more details & to get this sorted out at the earliest. We've dropped you a personal message and would request you to respond to the same.
    Regards,
    Ankita
  3. Ankita_S.
    OnePlus Bug Hunter Staff Member Sep 20, 2021
    Ankita_S. , Sep 20, 2021 :
    We have made a note of this and our developer team is currently working on this. We will keep you posted regarding the further updates. We appreciate your support and patience in this regard.
    Regards,
    Ankita
