[Submitted] Widevine downgraded to L3
  1. brueone
    Cupcake Jun 18, 2021
    brueone , Jun 18, 2021 :
    Widevine was downgraded to L3. No hd, nor hdri for Netflix.
    Restored everything and tried every single tip I found in the forums. No luck.
    Please fix this.
    OS 11.0.6.6.IN11BA
    Timothy1989 likes this.
  2. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Jun 19, 2021
    Suhas Klkrn555 , Jun 19, 2021 :
    We may have to check this further. Kindly check you're inbox we've dropped you a direct message. It'll be of great help if you could share the required information.
    Thanks & Regards,
    Suhas.
  3. brueone
    Cupcake Jun 20, 2021
    brueone , via OnePlus 8 Pro , Jun 20, 2021 :
    17:52:40.663 976 1184 E QCOM-OEMCrypto: Error at load_license : 158 06-19 17:52:40.663 976 1184 I QCOM-OEMCrypto: License: Widevine: NO CPZ: NO 06-19
    17:52:40.664 976 1184 D QSEECOMAPI: QSEECom_get_handle sb_length = 0x64000 06-19
    17:52:40.664 976 1184 D QSEECOMAPI: App is not loaded in QSEE 06-19
    17:52:40.665 976 1184 E QSEECOMAPI: Error::Cannot open the file /vendor/firmware_mnt/image/widevine.mdt errno = 2 06-19
    17:52:40.665 976 1184 E QSEECOMAPI: Error::Loading image failed with ret = -1 06-19 17:52:40.667 976 1184 D QSEECOMAPI: QSEECom_get_handle sb_length =
    18:00:22.157 976 1184 E QCOM-OEMCrypto: Error at _oecc05 : 754 06-19
    18:00:22.158 976 1184 W WVCdm : [oemcrypto_adapter_dynamic.cpp(916):LoadLevel1] Could not find /factory/wv.keys. Falling Back to L3. 06-19
  4. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Jun 22, 2021
    Suhas Klkrn555 , Jun 22, 2021 :
    We appreciate your efforts to get the required information, Not to worry, our dev team is already working on this and will make sure to get this sorted at the earliest.
    Thanks & Regards,
    Suhas.
    brueone likes this.
  5. abdullah13042000
    Gingerbread Jun 23, 2021
