OxygenOS Widevine L3 - Will it return to L1 after relock, or is there any way to have L1 on custom ROMs?
  1. rrobinson1216
    Gingerbread May 25, 2018
    rrobinson1216 , May 25, 2018 :
    See title - I get that if it's locked, it's L1 - Google Pixel 2 is L1 on both...if we relock will we get L1 again, and/or can custom ROMS get around this?
  2. idkwhoiam322
    Nougat May 25, 2018
    idkwhoiam322 , May 25, 2018 :
    OnePlus 6 comes with drm l1 and Netflix hd support. To read drm keys, you now need a locked bootloader, it is now a requirement. Unlocking will make them unreadable(L1->L3), but not delete the keys, so relocking will give you L1 again.
    SoniaB, elanglois and Android450 like this.
  3. rrobinson1216
    Gingerbread May 26, 2018
    rrobinson1216 , May 26, 2018 :
    It's a requirement by who, exactly? Why can the Pixel 2 keep L1 unlocked but the OP6 can't is the question, I suppose.
    elanglois likes this.
  4. elanglois
    Lollipop May 26, 2018
    elanglois , May 26, 2018 :
    How does it make them unreadable? With root, all things are possible.
  5. rrobinson1216
    It's quite a disappointment to me. Not sure if I'll keep the OP6 now based on that, because I love to mod but also enjoy Netflix. What happened to being very Dev friendly?
  6. Vansh99
    Ice Cream Sandwich May 26, 2018
    Vansh99 , May 26, 2018 :
    Widevine L1 certification is separated from the ROM. Loading a custom ROM or rooting your phone won't make it L3. Take it from a OnePlus 5 user with rooted phone.
  7. idkwhoiam322
    Nougat May 26, 2018
    idkwhoiam322 , May 26, 2018 :
    Google. Ask them, they do shit like this all the time, wew. It's a new requirement. Even the 5/T can be unlocked without losing the ability to read DRM keys.
    Afaik, it's stored in a separate partition. Magisk should be able to be able to make it readable, but only time will tell.
    It's a new thing.
  8. elanglois
    Magisk shouldn't have anything to do with it. Root is root, which means we could back it up with twrp, etc. The library that reads the partition just craps out if the bootloader is unlocked, but we can get around that! Maybe Xposed or something.
    idkwhoiam322 likes this.
  9. idkwhoiam322
    Nougat May 26, 2018
    At this point magisk is root hahahaa
    Yep, doesn't really sound the worst actually. But it's too soon to say. Not watching the cl final? :)
  10. elanglois
    CL Final????
    I wonder if the libs are compatible enough to where we can migrate the 5T libs that don't care about the unlocked bootloader, over to the 6?
  11. idkwhoiam322
    Nougat May 26, 2018
    I don't think anyone will go that route, it's not just the OnePlus 6, it's all new devices that will have to follow this, sadly.
    UEFA Champions League!!!
  12. elanglois
    If it doesn't have a CPU, I'm not interested
  13. GeertBerkers
    Lollipop May 28, 2018
    GeertBerkers , May 28, 2018 :
    I can confirm we get L1 back after relocking. Tried it myself.
    Still unavailable to use Google Assistent with Netflix on L3 :(
    Netflix not shown in Play Store, but can install .apk file.
    Does work with L1...
  14. cciechad
    Froyo May 28, 2018
    cciechad , May 28, 2018 :
    Can someone at OnePlus please explain how the system works and tells if the bootloader is locked?
  15. Ice_machinE
    Honeycomb Sep 28, 2018
    Ice_machinE , Sep 28, 2018 :
    Has anyone found a way to "raise/lower" the levels from 3 to 1 *with* unlocked bootloader?
  16. AzagraMac
    Cupcake Oct 26, 2018
  17. dsmonteiro
    Community Consultant Community Expert Oct 30, 2018
  18. AzagraMac
    Cupcake Oct 30, 2018
  19. dsmonteiro
    dsmonteiro , Oct 30, 2018 :
    That's strange. When did you first realized this change happened? Did you buy the device directly from OnePlus?
  20. anupritaisno1
    KitKat Oct 30, 2018
    anupritaisno1 , Oct 30, 2018 :
    It's stored in hardware, fuses or security tokens might also be used so no, you can't just use root to access it
    If you got root on a locked bootloader it would be a different story
