widget for sound volume
  1. TheGoatYeah
    Cupcake Oct 2, 2020
    TheGoatYeah , Oct 2, 2020 :
    Hello I have a physical issue with sound buttons on my OP5 and can't change the volume easily anymore. I was wondering if there is way to have volume as a widget on your phone or something of the same kind to bypass this mechanical issue faster than settings>sound>adjust volume
  2. Oreo.
    OnePlus Accessory Tester Oct 22, 2020
    Oreo. , via OnePlus 5 , Oct 22, 2020 :
    Use Google Assistant to adjust volume of your device. It also provides you the interface to manually adjust the volume.
    Tokolozi likes this.
  3. superplus
    Head Moderator Head Moderator Oct 22, 2020
    superplus , Oct 22, 2020 :
    Sorry to hear you're facing issues with your volume rocker. Depending on where you are and if you could go into a Service Centre, you could check to see if you could have it replaced, though I can't see the part listed on the repair costs sheet (https://www.oneplus.com/support/repair-pricing/details?code=5), so it would be worth contacting Customer Support (https://www.oneplus.com/support) first to enquire about the costs.
    With regards to your suggestion, you could consider submitting it to the Ideas 2.0 campaign (for example the option to add volume control to the dropdown tiles): https://www.oneplus.com/communityideas#/introduction or alternatively as a suggestion in the Feedback forums: https://forums.oneplus.com/feedback/
    Nice, but not everyone uses Google Assistant I guess ;)
    Oreo. and Tokolozi like this.
  4. Oreo.
    superplus likes this.
