Wifi 5Ghz Disconnecting problem via OnePlus 7 Pro
  1. Suresh raina
    Cupcake Jun 18, 2021
    Suresh raina , via OnePlus 7 Pro , Jun 18, 2021 :
    I have installed new wifi router recently.......I was trying to connect wifi in oneplus 7 pro .....It was perfectly fine in 2.4Ghz but in 5Ghz it keeps disconnecting and connecting repeatedly it was really annoying....Is there any solution for it to fix it ......
    1. I have done forgot network and resetting the network
    2.Safe mode and checked wifi
    But the same issue is still there 😔
  2. KluGe
    Lollipop Jun 18, 2021
    KluGe , Jun 18, 2021 :
    Maybe using Search can give you answers ...
    It is the rectangle in the upper right corner. ;)
    Artemus. likes this.
  3. Artemus.
    Community Hero 2020 Jun 18, 2021
    Artemus. , Jun 18, 2021 :
    Do you have MAC filtering enabled on the router?
