17
WiFi 6 in OnePlus 7 Pro
  1. BeingIncog
    Nougat Feb 8, 2021
    #41
  2. liweichen6
    Cupcake Feb 9, 2021
    #42
  3. EN7R0PY
    Cupcake Feb 9, 2021
    EN7R0PY , via OnePlus 7 Pro , Feb 9, 2021 :
    https://www.anandtech.com/show/1370...s a result, the 855,standard as it will stand.
    they can support the majority of the standard if not all. the main part would obviously be ofdma.
    You clearly don't know what you're talking about.....
    #43
  4. BeingIncog
    Nougat Feb 9, 2021
    #44
  5. ShadowFreak99
    Gingerbread Mar 25, 2021
    #45
  6. dr3am_r
    Gingerbread May 2, 2021
    dr3am_r , May 2, 2021 :
    I will check next week when my Xiaomi AX3600 Wifi 6 Router comes, but based on @liweichen6 screenshots, seems like our Oneplus 7 Pro might be capable of Wifi 6 (AX) on two streams and also 160mhz channel which is awesome. So using Wifi 6 on two streams and channel width of 80mhz the max connection speed would be 1200Mbps (up from 866Mbps from Wifi 5 / AC), but on 160Mhz channel, connection speed would double, up to 2400Mbps !!! And previous screenshot of @liweichen6 shows a connection speed of 1733Mbps (up from 1200Mbps only on 80Mhz band) which would confirm this.
    Just as confirmation, on Beta 4 Oxygen OS 11, I am still able to see Wifi 6 networks around me, but only Wifi 6 on 2.4Ghz (possible no 5Ghz network, as it seems it is a network of an extender).
    #46
  7. dr3am_r
    Gingerbread May 6, 2021
    dr3am_r , May 6, 2021 :
    @liweichen6 what version of the Oneplus 7 Pro do you have ? Is it the US/T-Mobile one ? As with my new WIFI 6 AX router I could not get past 866Mbps (same as on the Wifi 5 / AC) on Beta 4 Oxygen OS 11 (global phone version). My wife's Samsung S10 can connect up to 1200Mbps and it mentions it is Wifi 6. No luck.
    #47
