7
wifi and hotspot at the same time
  1. bdbright72
    Eclair Jun 12, 2018
    bdbright72 , Jun 12, 2018 :
    The one plus should work for wifi and the hotspot on at the same time, this feature should have provide in the next update.
  2. Prcko
    KitKat Jun 12, 2018
    Dark_Matrix_Guru likes this.
  3. bdbright72
    Eclair Jun 12, 2018
  4. Prcko
    KitKat Jun 12, 2018
    Prcko , Jun 12, 2018 :
    how do you want to use it? when you connect to a wifi you do not use mobile data. when you need to have data turned on as a hotspot. how can these two things work at the same time?
  5. MentalDraco
    Marshmallow Jun 12, 2018
    MentalDraco , Jun 12, 2018 :
    Magic.?
  6. Prcko
    KitKat Jun 12, 2018
    I can't find logic why you want to use your phone like WiFi repeater.
  7. Tom_lecter
    Ice Cream Sandwich Jun 12, 2018
    Tom_lecter , Jun 12, 2018 :
    Why use your phone as hotspot and drain battery when you can connect your other device directly to the WiFi router!
    macemoneta and otto2 like this.
  8. Punk_69
    Lollipop Jun 12, 2018
    Punk_69 , Jun 12, 2018 :
    Lol wtf?!
    Wifi and hotspot cannot work at the same time.....
    Eustacio Sealy likes this.
  9. bdbright72
    Eclair Jun 12, 2018
    It will work, just search in the youtube
  10. bdbright72
    Eclair Jun 12, 2018
    it will work properly
  11. Prcko
    KitKat Jun 12, 2018
    abcd68900
    It will work, just search in the youtube​
    yes like repeater......not like hotspot. please add link to the video becouse lot of us don't understand what you mean
  12. Tom_lecter
    Which task do you want to do by activating WiFi and hotspot simultaneously?
    astakhovoo likes this.
  13. bdbright72
    Eclair Jun 12, 2018
    have you seen the new redmi phones??..they can connect to a internet conncted wifi and provide hotspot at the same time...isnt it useful when ur stupid friends ask for net but ur too selfish to share your own internet...
    shemanth777 likes this.
  14. bdbright72
    Eclair Jun 12, 2018
  15. Tom_lecter
    Then give them the WiFi password you are connected. Both the party will enjoy! No unnecessary battery drain of your phone!
  16. MartinRo
    Gingerbread Jun 12, 2018
    MartinRo , Jun 12, 2018 :
    Ok, some (very specific) usage case: Our company has a very very strict firewall policy in the normal ethernet connection but at the same time you can use the companies mobile-wifi to reach the blocked sites (and ports). But mobile-wifi don't work with the normal computer so you can't directly connect to it. So if I would be able to use my phone as a "repeater" for wifi, I would be able to connect the computer over the phone with the mobile wifi to reach the blocked sites^^
    shabs_88 likes this.
  17. youbi
    Head Moderator Head Moderator Jun 12, 2018
    youbi , Jun 12, 2018 :
    But why can't they join by themselves to that same wifi?
  18. MartinRo
    Maybe because you don't want to give them your home wifi password ?
    the hotspot password is changed faster than that of your home wifi...
    otto2 likes this.
  19. gubro
    KitKat Jun 12, 2018
    gubro , Jun 12, 2018 :
    This is a stupid idea.
  20. gubro
    KitKat Jun 12, 2018
    Your company has a strict policy for a reason.
