Network/Connectivity Wifi and T-Mobile network
  1. tuanv1966
    Froyo Jul 29, 2019
    tuanv1966 , Jul 29, 2019 :
    I've had this issue before with my LG V20 on Verizon. So let's say I walked into a Wifi area and it shows, "XFinity Wireless", even though I'm not connected to it. I can't seem to get on the internet through T-Mobile. It just sits there. Now, if I disable Wifi, it will now switch to the my mobile network. Can anyone explain this?
    You'd figure if you went into a Wifi area that you've been before, it would auto connect and you're good to go. If it doesn't connect, my mobile should still work until I put in the correct password and allow it go off of Wifi.
    But the point being, I should ALWAYS be connected, either through wifi or mobile.
