wifi automatically disconnects and then connects again
  1. abhaykanodia
    Donut Aug 5, 2020
    abhaykanodia , Aug 5, 2020 :
    Hi All,
    I am facing an issue where my wifi automatically disconnects and then again connect to same network. I have tried reseting the network settings but it didn't work. Router restarted re configured but still no help. Something with the phone it seems. Please help.
  2. Caomhin
    Marshmallow Aug 5, 2020
    Caomhin , via OnePlus 6T , Aug 5, 2020 :
    If your router is capable of 2.4ghz and 5ghz make sure the SSID Name for each is different, you can edit the SSID Name on the Router Admin page.
    Also check your router broadcast channels for interference, change them to other channels if you find a nearby router broadcasting on the same channel as yours.
    Use a WiFi analyzer to check.
    I use this one from the Playstore to check for nearby routers using the same channel as me, and I switch my channel on the router to suit.
    https://play.google.com/store/apps/details?id=com.vrem.wifianalyzer
    Also a suggestion here for 8 Series but some of the suggestions may crossover to 6 series and others.
    https://forums.oneplus.com/threads/my-findings-of-the-5-ghz-wifi-connection-issue.1221263/
