14
WiFi Calling and VoLTE on Three UK Working!!
  1. bigalfazer
    Cupcake Jun 11, 2019
    #61
  2. snoop85
    Froyo Jun 12, 2019
    snoop85 , Jun 12, 2019 :
    I have switched on, however I don't see the icon in the status bar. However when I swipe down into the notification, I can see the icon. Is this normally behaviour?
    #62
  3. DeadEyeP
    Froyo Jun 12, 2019
    DeadEyeP , Jun 12, 2019 :
    yes
    #63
    snoop85 likes this.
  4. ballibeg
    Donut Jun 25, 2019
    ballibeg , Jun 25, 2019 :
    Well I have VoWIFI and VoLTE working on EE in Sim 2 but neither on my three Sim in slot 1. I called Three who said they don't support my 3T.
    This is doing my head in as I relied on 3 in touch a lot.
    Grrrr
    Dave
    #64
  5. Andy
    Gingerbread Jun 26, 2019
    Andy , Jun 26, 2019 :
    I have a 6T on 3. Anyone in the same boat given this a try?
    #65
  6. Nichrome
    Honeycomb Jun 26, 2019
    Nichrome , Jun 26, 2019 :
    OP6T, bought as SIM free phone, being on Three UK (for sake of science, unltd data, mins and texts)
    VoWiFi works fine. Got the icon, when getting a call it clearly says it's via wifi.
    VoLTE does not work. Been in touch with carrier three times and they always say "rest assured it will work 100%", well, no. It does not. Even took screenshot of my livechat. Note that all time I have 4G+
    VoLTE? Nah...
    And Vowifi. Yes!
    #66
    ballibeg and DeadEyeP like this.
  7. ballibeg
    Donut Jun 26, 2019
    #67
  8. ballibeg
    Donut Jul 1, 2019
    #68
    DeadEyeP likes this.
  9. Nichrome
    Honeycomb Aug 12, 2019
    Nichrome , Aug 12, 2019 :
    I moved my number to Vodafone and VoLTE got automatically enabled. Now that they offer unlimited data, and I have a lot better transfer speeds when at home, that kind of switch was a no brainer.
    #69
  10. __AK__
    Gingerbread Aug 12, 2019
    #70
  11. kikujiro38
    Eclair Aug 19, 2019
    #71
  12. __AK__
    Gingerbread Aug 20, 2019
    __AK__ , Aug 20, 2019 :
    Gave this a try, I couldn't get the app on my computer to work, it wouldn't let me select any options after right clicking. Gave up.
    #72
  13. kikujiro38
    Eclair Aug 20, 2019
    kikujiro38 , Aug 20, 2019 :
    I ran the PDC app as a system administrator and it works fine. if your phone is plugged in and the serial mode is enabled you should be able to select it in the drop down at the top of the app. it was a bit clunky for me. When I pressed the drop down it takes 1-2 seconds to show my phone in the list. Have you also installed setupvolte.exe ?
    #73
  14. Peterkin1010
    Cupcake Aug 21, 2019
    #74
  15. DeadEyeP
    Froyo Aug 21, 2019
    DeadEyeP , Aug 21, 2019 :
    vowifi works on three, volte only on the 5 or 3 (maybe the 7 now, I don't have one)
    #75
  16. __AK__
    Gingerbread Aug 22, 2019
    __AK__ , Aug 22, 2019 :
    The issue I'm facing is that serial keeps turning itself off, I enable it and go into the PDC app and it doesn't show my device, if i check on my phone by going back onto *#801# it shows serial as off again.
    Edit:
    I've managed to get it to work now, restarted my phone a few times and has been working since.
    India-VoLTE-Vodafone or Telefonica_UK_Commercial - Didn't work for more than a minute.
    The only one that worked for me was: H3G_Denmark_Commercial
    #76
  17. __AK__
    Gingerbread Oct 9, 2019
    __AK__ , via OnePlus 6 , Oct 9, 2019 :
    Is anyone having issues with data since following the instructions to force enable VoLTE since the last update? I'm struggling with 4G working and have to turn it off and use 3g for faster data connection.
    #77
  18. Percy247
    Cupcake Oct 18, 2019
    Percy247 , Oct 18, 2019 :
    Vowifi has stopped working for me in the UK on three network since it went down this Wednesday. Anyone else had this problem and if so has the service been restored or have you managed to sort it some other way. I have no cell signal at home so this is causing me a lot of grief!
    #78
  19. Tommy11
    Gingerbread Oct 18, 2019
    Tommy11 , Oct 18, 2019 :
    It's not been working very well for me these past couple of days either. I'm away visiting family and the mobile reception is poor at this location and the lack of WiFi calling had been noticeable. That said right now I've got Vowifi on both Sims (3 and Voda) and I've been able to do the test whereby I put the phone in to airplane mode then enable only WiFi and both networks connect and I can make calls.
    #79
  20. __AK__
    Gingerbread Oct 19, 2019
    __AK__ , via OnePlus 6 , Oct 19, 2019 :
    WiFi calling hasn't been working for me either, I'm out of town and signal is bad here, had to rely on only WhatsApp calling over WiFi.
    #80
