6
Network/Connectivity
WIFI connected but no Internet
  1. Rodog1076 Cupcake Jan 20, 2019
  2. H1546943959252 Cupcake Jan 20, 2019
    H1546943959252, Jan 20, 2019 :
    Same problem here since 9.0.2 on oneplus 6.
    9.0.3 do not clear the problem.
    Only happen to me on a 5Ghz wifi when the signal is between good and excellent.
    The same signal was working very well with 9.0 in the same room with the same signal strength.
  3. JJ6T Cupcake Jan 21, 2019
    JJ6T, Jan 21, 2019 :
    Did you get any solution?
  4. JJ6T Cupcake Jan 21, 2019
    For me the wifi connectivity is lost within 10 minutes, I have got to turn off and on the wifi for it to work..
  5. EddieBergman07 Cupcake Jan 22, 2019
    EddieBergman07, Jan 22, 2019 :
    I'm on Oxygen OS 9.0.11, and my Wi-Fi keeps disconnecting as well, even after I've reset the Wi-Fi settings
  6. EddieBergman07 Cupcake Jan 22, 2019
    The weird thing is that it downloaded movies through the night without any issues, but during the day it won't stop disconnecting.
  7. JJ6T Cupcake Jan 23, 2019
    JJ6T, Jan 23, 2019 :
    have you reported to support(https://forums.oneplus.com/feedback/), and did they provide any solution?
  8. EddieBergman07 Cupcake Jan 23, 2019
  9. abhibnl Ice Cream Sandwich Jan 23, 2019
    abhibnl, Jan 23, 2019 :
    Out of curiosity, why aren't you on 5.0.8 on 3T? 5.0.1 is a fairly old OOS version. There have been many changes after that to the system. I am on 5.0.8 currently and have no issues at all when i am at home connected to Wi-Fi. If nothing works for you (cache clearing, forgetting network and re-entering password etc), you might have to perform factory reset at the end.
  10. EddieBergman07 Cupcake Jan 23, 2019
    EddieBergman07, Jan 23, 2019 :
    abhibnl
    Out of curiosity, why aren't you on 5.0.8 on 3T? 5.0.1 is a fairly old OOS version. There have been many changes after that to the system. I am on 5.0.8 currently and have no issues at all when i am at home connected to Wi-Fi. If nothing works for you (cache clearing, forgetting network and re-entering password etc), you might have to perform factory reset at the end.​
    You've misread, I'm on version 9.0.11
  11. EddieBergman07 Cupcake Jan 23, 2019
  12. abhibnl Ice Cream Sandwich Jan 23, 2019
    You've misread. I am asking the OP. There is no 5.0.11 for 3/3T. Also your previous post said 9.0.11. I think you really need some clarity on what version of OOS are you using.
  13. EddieBergman07 Cupcake Jan 23, 2019
  14. frf88 Cupcake Jan 24, 2019
    frf88, Jan 24, 2019 :
    Same issue here... My Wi-Fi Data usage is at 100%.... I never used a data limiter for WiFi... And also my WiFi connection was set as Metered.. I changed ir to Unmetered and it's still not working.... OP 5 with 9.0.3
  15. A1522035574433 Cupcake Jan 24, 2019
    A1522035574433, Jan 24, 2019 :
    Same here after the update to 9.0.0 on the 5T it says connected to wifi at work but no internet while all the other devices have internet.
    The hotel wifi does work.
  16. Rololo88 Cupcake Feb 5, 2019
    Rololo88, Feb 5, 2019 :
    When you connected to your WiFi network and get not internet issue, just disable "mobile data" then you will get internet access back. I found this fix. Maybe the developer's team of OnePlus can look into it this bug.
    Cheers.
  17. Namirus Cupcake Feb 8, 2019
    Namirus, Feb 8, 2019 :
    Had the same problem and got it working.
    I set the CloudFlare 1.1.1.1 dns on my phone and removing the dns made it start to work.
    The reset of network settings didn't reset that. I had to do it manually.
    Hope it works for any of you. Let me know if it does
    F_Kuba_Wroński_vtQW likes this.
  18. F_Kuba_Wroński_vtQW Cupcake Feb 15, 2019
    F_Kuba_Wroński_vtQW, Feb 15, 2019 :
    Namirus
    Hope it works for any of you. Let me know if it does​
    Thanks, it worked for me. Had the same issue as ppl above and the only thing that helped was removing the DNS and setting IT to auto.
    #38
  19. CarlosRod35 Eclair Feb 17, 2019
    CarlosRod35, Feb 17, 2019 :
    Hi there, did you fixed it? I got a 5T and since yesterday I'm having the same issue, just with and specific network, that's odd.
    #39
  20. EddieBergman07 Cupcake Feb 18, 2019
    EddieBergman07, Feb 18, 2019 :
    So simply turning off the Private DNS seems to have done the trick for me. Wifi was constantly dropping before, but now it seems alright.
    #40
