8
wifi connection is unstable in OnePlus 5
  1. shgaurav
    Eclair Jun 27, 2017
    shgaurav , Jun 27, 2017 :
    you should post your reply as a message. I also setup my phone as new rather than copying over files. Other people might find your reply really useful so it will be better to reply to the thread itself. :D
    #81
  2. Vinothus
    Donut Jun 27, 2017
    #82
  3. cole.godberson
    Gingerbread Jun 27, 2017
    #83
  4. yycboilerclean
    Cupcake Jun 27, 2017
    yycboilerclean , Jun 27, 2017 :
    I was also having many problems with wifi and some apps not loading after I set up my new OP5 from my old phone using NFC.
    Today I reset phone and set up as new phone and all the previous issues are gone. Works on 5 or 2.4 and all apps are working normally.
    I hope this helps some others with their issues. It's no fun having trouble with a new phone.
    Good luck gang.
    #84
  5. someone91732
    someone91732 , Jun 27, 2017 :
    have you checked with your internet service provider for possible outage? had that happen on my S80+ before I switch to the OnePlus5 and turns out it was my internet service provider.
    #85
  6. willsium
    Eclair Jun 27, 2017
    willsium , Jun 27, 2017 :
    I have the 4.5.2 update and my wifi still has issues, drops out all the time as soon as I get more than a few feet from the router. My OP1 has no issues in the exact same place so something is wrong.
    #86
  7. Stow
    #87
  8. Muffin.5353
    Eclair Jun 27, 2017
  9. Senti3nt
    Ice Cream Sandwich Jun 27, 2017
    Senti3nt , Jun 27, 2017 :
    New update 4.5.3 has been rolled out and hopefully it will fix the WiFi issue which some people are having. I I didn't have any issue has off now. I have done
    #89
  10. mlnaras
    #90
  11. JapserB
    Froyo Jun 27, 2017
    #91
  12. Prizi
    Donut Jun 27, 2017
    Prizi , Jun 27, 2017 :
    Version 4.5.3 helped in my case. WiFi is now working with 5g without interuptions.
    #92
  13. Frederickc
    Honeycomb Jun 27, 2017
    Frederickc , Jun 27, 2017 :
    Maybe if we can understand what it is what they have changed, we can find the source of the problem.
    #93
  14. ravi binan
    #94
  15. blinkxguna
    blinkxguna , Jun 27, 2017 :
    Oneplus Team,
    My Oneplus 5 8Gb model does not detect wifi at home. I have updated to latest firmware. Without the wifi seems like a brick in the hand. Please Please fix the wifi detection issues.
    Let me know if you need more input...
    Thanks
    Guna
    #95
  16. PandaGoesNomNom
    Eclair Jun 27, 2017
    PandaGoesNomNom , Jun 27, 2017 :
    I've had the same issue. I've had to stand within 5-6 feet of the router.
    i tested it against my old Nexus 6 on a speed test and several other apps. Nexus had no troubles. OP5 failed to work until within extremely close range.
    I hope this will be fixed in a patch
    #96
  17. PandaGoesNomNom
    Eclair Jun 27, 2017
    *update* I performed the test both before and after the update. no change.
    #97
  18. jameswalker457
    Eclair Jun 27, 2017
    #98
  19. GeorgyFelix19
    Donut Jun 27, 2017
    #99
  20. counttom
    Eclair Jun 27, 2017
    counttom , Jun 27, 2017 :
    4.5.3 should fix the issue, and you just disabled DFS which fixes the issue but you're losing bandwith and signal
