3
Wifi connection issue after update
  1. Q1554167564223
    Cupcake Jan 8, 2020
    Q1554167564223 , Jan 8, 2020 :
    After the recent android 10.3.0 update my wifi is getting randomly disconnected. No matter what i do the problem still persist. I noticed so many of you have the same problem. If some has a solution please let me know as it is getting really annoying.! Why is oneplus not responding to it? Hope this gets sorted out the earliest.
  2. max_kr
    Cupcake Jan 8, 2020
    max_kr , Jan 8, 2020 :
    Hi, I have the same issue since upgrade vom Oxygen 9 to 10: If my phone is in standby it has no connection to my provider (might be poor signal at home) and no Wifi. It takes up to 30s seconds connecting to WiFi (5GHz) again.
    Very annoying. Never had such problems with Oxygen 9. Is there a solution or workaround?
    Regards,
    Max
  3. Caomhin
    KitKat Jan 8, 2020
    Caomhin , via OnePlus 6T , Jan 8, 2020 :
    Reset your WiFi on the phone. Go to Settings, System, Reset Options, Reset WiFi, see if this helps
    DrJMun and max_kr like this.
  4. Ed Jones
    Froyo Jan 9, 2020
    Ed Jones , Jan 9, 2020 :
    My WIFI and Bluetooth are both unstable. Doing a Reset only helps for maybe 1-2 days and then I am back to them being unstable.
    There has been enough time for this to have been researched and fixed.
    Android 10 should not have been released until it had been completely tested.
    Q1554167564223 and mitgsx like this.
  5. Z1578579701907
    Cupcake Jan 10, 2020
    Z1578579701907 , Jan 10, 2020 :
    Hello,
    I see this issue on my phone as well. Happens only when i am connected to the 5GHz wifi. 2.4 GHz wifi works fine.
    This issue was not there before the upgrade. This is very annoying. Please fix.
    Thx,
    Pavan
  6. max_kr
    Cupcake Jan 16, 2020
    max_kr , Jan 16, 2020 :
    I have still problems after resetting as described by Caomhin.
    Also using WiFi at 2.4GHz is not very stable at all, but better than 5GHz. Is there no other solution?
  7. Caomhin
    KitKat Jan 16, 2020
    Caomhin , via OnePlus 6T , Jan 16, 2020 :
    Check here if to see if it can resolve the issue.
    https://forums.oneplus.com/threads/android-10-wifi-failed-to-connect-fix.1133014/
  8. max_kr
    Cupcake Jan 17, 2020
  9. Caomhin
    KitKat Jan 17, 2020
    max_kr likes this.
  10. Kytharsis
    Nougat Jan 17, 2020
    Kytharsis , Jan 17, 2020 :
    WPA? Why the hell are you still on WPA?
    Caomhin likes this.
  11. max_kr
    max_kr , Jan 17, 2020 :
    Thank you for the hint Caomhin.
    @Kytharsis: Caomhin described above that there is a solution if you change router setting to WPA...
    ...but not a solution for me!
