wifi connection problem via OnePlus 6T Mirror Black
  1. MILANFINE1024 , via OnePlus 6T Mirror Black , May 27, 2020 :
    hi! I use the OP6t and since the last update I have been facing WIFI issues....first of all it takes a hell lot of time to connect to the wifi and if it gets connected it will disconnect itself after 30 mins or so and the wifi gets cut off all of a sudden and it's really pissing off.
    I also have a OP5 which is not facing any such issues....by which it can be concluded that it's not the problem of the router or the wifi connection...it's a BUG IN THE PHONE/LATEST UPDATE. hopefully this problem will get fixed ASAP or I would like to know an alternative to fix the problem.
    thankyou
  2. Caomhin
    OnePlus 9 Series Expert Community Expert May 28, 2020
  3. DavidG67
    Donut May 28, 2020
    DavidG67 , May 28, 2020 :
    I too have a similar problem. I am in a no mobile data area. I reset my router etc, restarted my phone. Toggles Wifi on/off, Airplane mode on/off. 'Forget' my wifi connection and reconnected with the correct password.
    OP A5000
    MILANFINE1024 likes this.
  4. #4
  5. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 4, 2020
