wifi connection
  1. DannyGill Cupcake May 25, 2019
    DannyGill, May 25, 2019 :
    anyone have some spotting wifi connection when I using my OnePlus 7 pro 12gig model on wifi it takes a few mins to load but if I'm using my s10 plus on the same wifi it's quick ...I turned the phone than back on and it's back quick so I'm not sure if it my phone or software issue...
  2. bowrycrue Cupcake May 26, 2019
    bowrycrue, May 26, 2019 :
    Yes, I have the same problem. Sometimes it stays steady, but once it disconnects, I have to reboot the phone. Going to airplane mode and back doesn't fix it. hope it gets fixed soon.
    DannyGill likes this.
  3. ddarden Cupcake May 31, 2019
    ddarden, May 31, 2019 :
    My wifi from OnePlus 7 pro is suspect at best. Compare it to my Pixel 2XL does not pick up signal at anywhere near the same strength. I have found that I must disconnect wifi in my house half the time because to your point it takes minutes to load simple websites like ESPN, CNN.
