wifi connectivity problem
  1. B1511789334119
    Froyo Dec 31, 2017
  2. AntStephenson
    Gingerbread Jan 1, 2018
  3. Novaol
    Novaol , Jan 1, 2018 :
    Better to check on your router side if you have given the correct password, and it is case sensitive too.. Just in case
  4. vpjoshi007
    Froyo Jan 1, 2018
  5. ɢноѕтΘпе
    Starting Point Expert Community Expert Jan 1, 2018
  6. sujithkumarb
    Froyo Jan 1, 2018
    sujithkumarb , Jan 1, 2018 :
    Even I have got the same prob, the password is correct but it just says password may be wrong. At the moment the workaround is to turn off the wifi for couple of minutes and turn it on again. But this should not be the case !!
