5
Wifi & Data Disconnection for OnePlus 7T via OnePlus 7T
  1. Priyankshah077
    Cupcake Apr 30, 2021
    Priyankshah077 , via OnePlus 7T , Apr 30, 2021 :
    -Bug after the OS11 Update the Wifi & data disconnects automatically in a span of after 3-4 Minutes
    -delay in displaying the call on the screen (the phone vibrates then after fraction of seconds the call appears on the screen)
  2. Fatih Aşkın
    Gingerbread Apr 30, 2021
  3. TheMystic
    Lollipop Apr 30, 2021
    TheMystic , Apr 30, 2021 :
    Settings/ WiFi & Network/ WiFi/ WiFi Preferences/ Intelligently select the best WiFi.
    Disable it. Reboot, if necessary.
  4. Priyankshah077
    Have tried everything it's a bug for everyone out there
  5. manisharora001
    Eclair Apr 30, 2021
    Opuser808 likes this.
  6. Opuser808
    Cupcake May 1, 2021
    Opuser808 , May 1, 2021 :
    I'm also having wifi and data disconnection issues since installing the update. I had contacted support twice today; both times they had me wipe cache (first time they also had me reset the network) - the issue persists. On the second support conversation I was told they're going to release another update to fix the bug, but this is extremely frustrating to deal with as it's affecting calls. I hope it's resolved soon.
    manisharora001 likes this.
  7. #7
  8. feei10254
    Gingerbread May 1, 2021
  9. KaustubhNaik95
  10. bvtd092
    Froyo May 2, 2021
    bvtd092 , May 2, 2021 :
    Hello,
    After searching a while I've found the following workaround.
    At home I have 2 wireless networks running on the same router, one at 2.4 Ghz and one at 5 GHz.
    Once both ssids have been connected, I afterwards get the phenomenon that the 2.4 Ghz SSID performs a connect and disconnect every 5 seconds. As soon as I forget the 5 GHz SSID on my Oneplus 7T phone, no more connect and disconnect is performed from the 2.4 GHZ SSID wireless network.
    This is a known problem since a long time. I've opened a bug report at Oneplus.
    https://forums.oneplus.com/threads/wifi-connects-and-disconnects-after-updating-android-11.1413280/
    You can find also a lot of information at the following link:
    https://piunikaweb.com/2021/03/29/o...-disconnection-issue-in-android-11-open-beta/
    Regards,
  11. K1574297729180
    Cupcake May 9, 2021
  12. foresee1900
    Donut May 11, 2021
  13. #13
  14. Teja_Ps
    Eclair May 11, 2021
  15. juttuka.pavan
    Honeycomb May 16, 2021
  16. Priyankshah077
    Cupcake May 24, 2021
  17. #17
  18. OALEXANDER
    Assistant Head Moderator Assistant Head Moderator May 24, 2021
    OALEXANDER , May 24, 2021 :
    Yes please, refer announcement thread - OxygenOS 11.0.1.1 for the OnePlus 7T Pro and OnePlus 7T - OnePlus Community
    • Network
      • Improved 4G network communication
      • Improved the stability of Wi-Fi connection
    Hope once you get the update , it will be fixed .
