Wifi Direct is disable condition in 7T, How to enable it?
  1. T1572261401933
    Donut Dec 2, 2019
    DUBBLE35 likes this.
  2. E1572463380558
    Cupcake Dec 2, 2019
  3. T1572261401933
    Donut Dec 3, 2019
    T1572261401933 , Dec 3, 2019 :
    still not able to connect.
    plz advice.
    samsung phones are easy to use.
    whereas oneplus i am struggling lot.
  4. #4
  5. sanjay7465
    Gingerbread Dec 4, 2019
    sanjay7465 , via OnePlus 7T , Dec 4, 2019 :
    You don't need to be connected on a WiFi network, only WiFi switch and "location" should be enabled to use WiFi Direct
  6. sanjay7465
  7. DUBBLE35 , via OnePlus 7T Pro Haze Blue , Dec 4, 2019 :
    Ohhhhhhhh my God Thank you ! I just don't know that I have to enable the location !
  8. sanjay7465
    Are you able to share file using WiFi Direct ?
  9. T1572261401933
    Donut Dec 5, 2019
    T1572261401933 , Dec 5, 2019 :
    Dear sanjay7465,
    Thanks a lot for your kind information
    After switch ON the location, Wifi direct got enabled.
    Really your feedback done a good job.
    But file sharing is not working (Oneplus 7T procedure)
    Step 1:
    Wifi ON --> location ON --> Wifi direct ON --> Tap to connect target phone --> connected Successfully with samsung phone wifi direct.
    Step 2:
    File manager --> Selected some files --> Tap to share option --> system share tray opened (But there is no any option called wifi direct to send a file)
    Hence file sharing is not working with wifi direct.
    As per people recommended to use ""File dash"" in file manager itself to send files.
    Whereas, it is more procedural and inconvenient to use.
    It has to be like click to send everything like samsung phones.
    Samsung is not required to switch ON the location to enable the wifi direct.
    If Wifi direct is ON directly, it will automatically switch ON the wifi also.(since without wifi, wifi direct can't provide service) Hence wifi direct become active to use without any berden.
    And also its not required to do anything, everything is simple to tap and click to share the files easy.
    In that way, samsung phones are good to use.
    I hope this information will useful for people, who are facing this issue in this forum.
    Oneplus should thing such a way that, to build basic requirements (simple file sharing is made more complex) is basement of software realibility and convenient to use the product, rather than focus the game mode, display options etc..
  10. T1572261401933
    Donut Dec 5, 2019
