Network/Connectivity Wifi Disconnectivity and Battery Drain issue.
  1. ap9225
    Cupcake Aug 1, 2021
    ap9225 , Aug 1, 2021 :
    1) Wifi with my one plus 8 keeps getting disconnect every couple of minutes. I checked all setting in my phone and also did a network rest. The issue still persists. The router at my home was checked too and it is fine as not other phone gets disconnected and its only mine. It is extremely irritating especially during important work.
    2) Battery drains too fast even when on idle and also when using.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 1, 2021
    Best Answer
    Dresa91 , Aug 1, 2021 :
    A little bit because you charged your phone a lot.
    But the drainers are:
    Battleground India and the display (no Wonder)
    The social media apps
    That’s totally normal that your battery drains.
    you can read:
    https://forums.oneplus.com/threads/updated-2021-no-more-lags-freezes-battery-drain-heating.1415175/
    https://forums.oneplus.com/threads/battery-analysis-and-battery-drain-trouble-solving.1413430/
    J4t1np4r3kh and ap9225 like this.
  3. Dresa91
    1) please reset your Network settings.
    2) what OxygenOS Version are you using? Can you please share your battery and usage stats?
  4. ap9225
    Cupcake Aug 1, 2021
    ap9225 , via OnePlus 8 , Aug 1, 2021 :
    1) Even after resisting network settings I am facing this issue.
    2) I am using 11.0.7.7 .
  5. Dresa91
    Did you clear cache in recovery?
    Did you submit a bug report?
    What about your battery and usage stats?
    J4t1np4r3kh likes this.
  6. ap9225
    Cupcake Aug 1, 2021
    I did clear cache and then did network reset.
    Bug report has been submitted.
    What exactly should I submit regarding the battery usage and stats?
  7. Dresa91
    Well the stats of the battery and app usage, which you can find in settings,….
  8. ap9225
    Cupcake Aug 1, 2021
    Does this help?
  9. ap9225
    Cupcake Aug 1, 2021
    Will this charging affect the battery or phone? And it was the same before bgmi. Like 2 weeks before.
  10. Dresa91
    The more often you charge, the greater the impact on battery life.
  11. ap9225
    Cupcake Aug 1, 2021
    In the coming future like a year or 2 or more recent?
  12. Dresa91
    Depends on how often, what you are doing while charging, how long you are charging the device, etc
  13. ap9225
    Cupcake Aug 1, 2021
    Noted. Thanks Buddy [e]1f60a[/e]
    Dresa91 likes this.
  14. Dresa91
    You are welcome:)
    ap9225 likes this.
