Wifi disconnects automatically via OnePlus 8 Pro
  1. Ritrai
    Gingerbread Jan 4, 2021
    Ritrai , via OnePlus 8 Pro , Jan 4, 2021 :
    I use WiFi all my day and there were no problems till now but today it suddenly disconnected by itself I tried to reconnect it it's not connecting. Tried resetting the Wifi, the device connection settings, reboot, switch off. The only help is I have to switch of the router and turn it back on if my phone get disconnected. Anybody any idea what is the issue?
  2. edge.s
    Gingerbread Jan 5, 2021
  3. Tokolozi
    Most Original Avatar Jan 5, 2021
    Tokolozi , Jan 5, 2021 :
    Indeed sounds like a router issue, maybe there's an IP conflict on your network?
    Are there any devices set to fixed IP or similar>?
    Bobbie63 likes this.
  4. Ritrai
    Ritrai , via OnePlus 8 Pro , Jan 5, 2021 :
    I checked and it was a router issue.
    edge.s likes this.
  5. Ritrai
    Don't know what you are taking about, but it is a router issue and maybe I have to go to the router's service center.
    Bobbie63 and Tokolozi like this.
  6. Tokolozi
    That would maybe be best. Or try a different one if you have the option.
  7. edge.s
    edge.s , via OnePlus 8 Pro , Jan 5, 2021 :
    You can try resetting your router as well in the mean time.
  8. Ritrai
