Wifi driver via OnePlus 5T
  1. Kashonline
    Donut May 15, 2020
    Kashonline , via OnePlus 5T , May 15, 2020 :
    I've been noticing slow internet since few weeks. I spoke to network provider and the speed test on my laptop shows 39mbps on ooklaspeedtest. The same speed test on my phone shows 12-16mbps. I've tried the same one OnePlus 6 which showed 15-20. The results persisted during multiple attempts and different days. Need some assistance with this.
    Thank you
  2. Liehjan
    The Lab Reviewer - OnePlus Buds Pro May 15, 2020
    Liehjan , May 15, 2020 :
    There are different antennas in all three devices, so you can't compare apples to apples... Also a speedtest is never the same twice in a row.
  3. Kashonline
    Donut May 15, 2020
    yes they have different antennas but the bandwidth I subscribed to is 40 Mbps. So less than 50% is a not a good thing I believe.
  4. Liehjan
    Put your phone on top of the router and do a new speedtest, it will surely be 30+
  5. Kashonline
    Donut May 15, 2020
    The results I mentioned were done the same way
  6. Liehjan
    Oh, the it might be something... Try to reset network settings on the phone.
  7. Kashonline
    Donut May 15, 2020
    Thank you!
    it worked. it's around 25mbps now. better than previous.
  8. Kashonline
    Donut May 17, 2020
    Kashonline , via OnePlus 5T , May 17, 2020 :
    it's happening again. even a regular game is lagging due to the slow speed. same speed test results in the same setting.
  9. Sunil+
    Froyo May 17, 2020
    Sunil+ , May 17, 2020 :
    Are the test servers same on both laptop and phone?
    Have you tried with another mobile?
  10. Kashonline
    Donut May 18, 2020
    Kashonline , via OnePlus 5T , May 18, 2020 :
    yes, I have tried it with OnePlus 6. the results were kind of the same.
  11. Sunil+
    Froyo May 18, 2020
    Sunil+ , May 18, 2020 :
    If possible try with another router - try the normal 2.4ghz on all devices.
    Select same test server.
    Kashonline likes this.
