Network/Connectivity WiFi filter for multicast
  1. DFosB
    Cupcake Apr 19, 2021
    DFosB , Apr 19, 2021 :
    I am using home internet provider who broadcast IPTV using multicast technology.
    I think it causes a quick discharge of OP 7T Pro battery with enabled WiFi at home.
    I have set the following setting in Developer's Settings:
    It is in Russian but i Think the correct translation is "Filter for application with network and broadcast parameters".
    However I don't like battery discharge and the only solution is to disable WiFi when not used - even at night when device is not used enabled WiFi leads to 10%-15% discharge with only 2%-5% with disabled WiFi.
    Possibly I did not understand the above mentioned setting and it should be disabled rather then enabled? Or is there any other solution for quick discharge in WiFi network with active multicast broadcasting?
