bhappyharsha , via OnePlus 8T , Dec 3, 2020 : Hi, I've been connecting my laptop to my phone's WiFi hotspot and after the laptop is connected, I see another connection without any details about the device that's connected. It just connects a minute or two later. Nothing happens if I disconnect that device. The laptop is connected alright. I'm wondering what's that and if there's a way to find that out. thanks for your time. edit: updated with an image regards, Sri Harsha
bhappyharsha , via OnePlus 8T , Dec 4, 2020 : Nothing happens. It just disconnects. No impact on my laptop or in the phone.
bhappyharsha , via OnePlus 8T , Dec 4, 2020 : It doesn't till I turn off the hotspot and turn it back on. Once I turn it back on, it connects.
rh94 , via OnePlus 3T , Dec 4, 2020 : It might be some IOT devices you're using which is automatically connecting to the hotspot. You can change your password and see if the aforementioned device is still connecting or not.
G_plusone , Dec 4, 2020 : I am assuming that changing the password doesn't work and the second device still is persistent. Maybe you could reset 'Network settings' ? Only Network settings
