[Submitted] Wifi is not connecting to a stable network
  1. H1626870115409
    Cupcake Jul 29, 2021
    H1626870115409 , Jul 29, 2021 :
    After the android 11 update, the wifi connectivity is misbehaving and is continuously connecting and disconnecting by itself even though all other mobile phones wifi connected to the same network are working fine. Can you please help, since i am facing such issue?
  2. Dipjyoti Nath
    OnePlus Bug Hunter Staff Member Jul 29, 2021
    Dipjyoti Nath , Jul 29, 2021 :
    Sorry to hear that you have been facing such an issue with your device while trying to maintain a stable WiFi connection. Apologizing for the inconvenience caused on that note. Hence, requesting you to kindly go through your personal message and help us with the required log information for further investigating into your concern.
    Regards,
    Dipjyoti
