11
Wifi issue on Oneplus 7 on Android 11
  1. harshsaraf90
    Cupcake May 2, 2021
    harshsaraf90 , via OnePlus 7 , May 2, 2021 :
    WIFI GETS DISCONNECTED AUTOMATICALLY AFTER ANDROID 11 UPDATE AND HAVE TO RECONNECT MANUALLY EVERTIME... ALSO THE ADAPTIVE BRIGHTNESS IS NOT WORKING PROPERLY..
    HAVE ALSO RESET THE PHONE TO FACTORY SETTINGS..STILL NOT RESOLVED.. KINDLY GIVE A SOLUTION
    Dhruv Kashyap likes this.
  2. Dhruv Kashyap
    Jelly Bean May 2, 2021
  3. sptripathii
    Eclair May 2, 2021
  4. amber.bhardwaj1 , via OnePlus 7 Mirror Gray , May 2, 2021 :
    This issue I'm facing on my Oneplus 7. I tried to contact the internet provider so they came and check everything but we both didn't find anything. So what i did:
    1. Check other mobile phones like motorola, oneplus 5t, oneplus 6, Redmi 9 pro max, Realme XT but none of them have this issue. I checked parallelly.
    2. I tried all kind of default solutions with phone like reset but not resolved.
    3. i tried to increase the Ips in router also but still same issue.
    --__-----------------
    Temporary Fix
    It's been 3+ hours my WiFi is stable and now, it's not disconnecting so to do this temporary fix i disabled the "Intelligently Select the Best Wifi" feature.
    Note:
    i have both 2G and 5G wifi connection and have latest Archer A5 router.
  5. ChristianLotino
    Gingerbread May 2, 2021
  6. harshsaraf90
    Cupcake May 3, 2021
  7. Gnanendra C Kotha
    Cupcake May 3, 2021
  8. waqas.akram77
    Cupcake May 3, 2021
    G1581529377935 likes this.
  9. lakshayarora1709
    Cupcake May 3, 2021
    lakshayarora1709 , via OnePlus 7 , May 3, 2021 :
    After installing the new update wifi keeps on disconnecting and connecting again...This makes me frustated...Oxygen OS is forgetting the reason why people used to trust them.
    Fix it asap!
  10. gdsingh94
    Jelly Bean May 3, 2021
  11. G1581529377935
    Cupcake May 3, 2021
  12. Slsriram
    Cupcake May 4, 2021
    Shub_19 likes this.
  13. A1573023771591
    Cupcake May 4, 2021
  14. nits1688
    Cupcake May 4, 2021
  15. O1580681268050
    Cupcake May 4, 2021
  16. Shrikant820
    Cupcake May 7, 2021
    Shrikant820 , via OnePlus 7 , May 7, 2021 :
    My wifi keeps disconnecting randomly and gets reconnected after some seconds. It impacts gaming primarily. The issue has started after the latest Android update.
    Suggestions are welcome to help me fixing this issue.
  17. Nikhil68
    Cupcake May 7, 2021
  18. Satyajit Mane
    Froyo May 7, 2021
    Satyajit Mane , via OnePlus 7 , May 7, 2021 :
    Try reset but be sure to backup all your data. Most of the problem get solved by reset.
  19. DineShMK1995 , via OnePlus 7 Mirror Blue , May 7, 2021 :
    Settings/ WiFi & Network/ WiFi/ WiFi Preferences/ Intelligently select the best WiFi.
  20. Satyajit Mane
    Froyo May 7, 2021
    No use.. software problem...need to wait for another bug fixes update
