11
Wifi issue on Oneplus 7 on Android 11
  1. harshsainii likes this.
  2. harshsainii
    Froyo May 8, 2021
    harshsainii , May 8, 2021 :
    OnePlus is purposefully rolling out bad updates without doing thorough testing. This is my last oneplus device. They are not respecting their customers anymore. Just wasting the resources on meaningless ventures (Hasselblad branding).
  3. D1563021325747
    Cupcake May 8, 2021
    D1563021325747 , May 8, 2021 :
    Hello.
    I use oneplus 7 and after I got updated os 11 there is a wifi connectivity issue that is after connected with any network it's saying no internet.
    So please anyone knows what's the solution to it.
    Resolve my problem.
    Thank you.
  4. vardhannaga
    Cupcake May 10, 2021
  5. AVShankar
    Cupcake May 11, 2021
    AVShankar , via OnePlus 7 , May 11, 2021 :
    Hello!
    I'm facing the WiFi connectivity issue after recent update to 11.0.0.2. Whenever the WiFi signal goes out of range and returns back, device is not getting connected automatically to the saved network. I have to manually turn off and on the WiFi to connect.
    And also I faced this issue only one time, I was not able anyone from dial pad or from contact book. Nothing is happening when I click on the call option. I had to restart the device to make it work.
    Does anyone face the same issue or similar to this after the update 11.0.0.2?
  6. gdsingh94
    Jelly Bean May 11, 2021
    Artemus. and Caoimhín like this.
  7. vky_25
    vky_25 , via OnePlus 7 Pro , May 11, 2021 :
    This wifi drop has been an issue since past one month after the update and still there's nothing from oneplus.. This is really surprising.. The USP of Oneplus was they knew their software very well and their updates were up to date.. No more the case.. Sad state of all mobile companies.
  8. 8_himanshured.Red8
    8_himanshured.Red8 , via OnePlus 7 , May 11, 2021 :
    Hi everyone,
    Since oxygen os 11 update i am facing frequent wifi toggling issue this is because of only one reason no issue with mac randomiation which everyone posting or network rating provider
    Issue is happening because device ia keep on refreshing dhcp address
    Best way to avoid as of now to set the ip manually
    That will resolve your issue
  9. Abhijitmarku
    Cupcake May 12, 2021
  10. gdsingh94
    Jelly Bean May 12, 2021
  11. pablofg1978
    Head Moderator Head Moderator May 12, 2021
    pablofg1978 , May 12, 2021 :
    THreads merged
  12. Prasann_Purwar
    Prasann_Purwar , via OnePlus 7 , May 12, 2021 :
    I am facing the same issue since I have updated to OS 11, wifi keeps on connecting/disconnecting all the time. I had a OnePlus 5 which had the same problem. So this is not something new, it's just that the support is not interested in fixing this issue.
  13. Harsha_Avvari
    Harsha_Avvari , via OnePlus 7 , May 12, 2021 :
    Hello Team,
    First of all, thank you so much for providing Oxygen OS 11 update for OnePlus 7 series and this move has enhanced our trust in your company. At the same time, update should enhance user experience but unfortunately this time Oxygen OS 11 is seeing some battery drain issue and WiFi connecting issues like WiFi is disconnecting abruptly. Please look into this and make our experience seamless.
  14. Aaron2017
    KitKat May 12, 2021
  15. pablofg1978
    Thread merged
  16. Woll
    Woll , May 12, 2021 :
    Also had this problem and sometimes still have trouble with it. In the beginning I did a restart and that helped for a while. Now if i have a problem with it is just turn wifif off and then on and it works. If this doesn't hold thé wifi icon for a while and click again on your wifi u want to use.
  17. Ramavath Rakesh
    Cupcake May 13, 2021
  18. uttam2808
    Donut May 13, 2021
  19. Krishna Prithvi
    Eclair May 13, 2021
