19
Wifi Issue with OnePlus 5
  1. hardikchouhan
    Donut Jun 25, 2017
    hardikchouhan , Jun 25, 2017 :
    Received my OnePlus 5 yesterday and got an update 4.5.1
    After finishing update and setting up the phone, I m facing an issue with WiFi connection. Phone drops WiFi connection frequently, though it is connected on wifi network but it says No internet connection. At the same Time I checked on other phone it has internet in same wifi.
    I have to Turn Off Wifi and again on it or have to reboot the phone to make it work again.
    I also tried clearing chache but it didn't work.
    Pls help...
  2. Koschel
    Cupcake Jun 25, 2017
    Koschel , Jun 25, 2017 :
    Pls help...
    F1517501673617 and vinodh_dasari like this.
  3. lugaru
    F1517501673617 likes this.
  4. daveyboyuk
    daveyboyuk , Jun 25, 2017 :
    I'm also facing exactly the same issue, after installing the Oxygen OS update for 4.5.1. However, if I toggle WiFi off and back on again, it occasionally starts working again. Lets hope they identify the issue quickly, otherwise our 3/4G data usage will soon be rising!
  5. Frederickc
    Honeycomb Jun 25, 2017
    Frederickc , Jun 25, 2017 :
    I've contacted customer support and they are aware of this issue and are looking into it. The rom team has been informed of the issue.The issue is prioritized so it seems :p. They propose to do a hard reset, but I don't believe that would solve anything.
  6. sonali93p
    sonali93p , Jun 25, 2017 :
    Hi. u just need to turn on the wifi. you will see a settings icon on the top. Click on that den turn off the option "smart wifi switcher" . You will automatically get connected to the wifi.
  7. JapserB
    Froyo Jun 25, 2017
  8. Nadiim87
    Nadiim87 , Jun 25, 2017 :
    I have the same issue. It's really annoying. Most likely a software issue.
  9. shivam_adi
    Donut Jun 25, 2017
  10. Maghuro
  11. Suzann1219
    Suzann1219 , Jun 25, 2017 :
    I have the same issue, but only with the wifi extender. My regular wifi works perfectly fine, but whenever I switch to the extender, it never works. Do you think this is a oneplus issue, or should I contact my internet provider? (cause the wifi extender works with any other device in the house).
  12. Frederickc
    I am sure it is an issue with the OP5
    F1517501673617 and Suzann1219 like this.
  13. G_Syed_Kamran_PTji
    Gingerbread Jun 25, 2017
  14. counttom
    Eclair Jun 25, 2017
  15. bhosalepriyanka
  16. counttom
    Eclair Jun 25, 2017
    counttom , Jun 25, 2017 :
    This seems to do the trick for me
    MatG-DK likes this.
  17. anuppradhanang
    anuppradhanang , Jun 25, 2017 :
    On my OnePlus5 running OxygenOS 4.5.1, connecting to 2.4 GHz performed better than 5GHz AC where it was timing out during speed tests and pages loaded slower. After turning off Smart WiFi switcher on settings of WiFi screen as suggested by sonali93p, it is performing well with speed tests as well as loading pages.
  18. anuppradhanang
    sycshk likes this.
  19. 0542
  20. counttom
    Eclair Jun 25, 2017
    So it seems to be that it's not playing nice with DFS in the 5GHz Wifi Spectrum , static 5Ghz and 2.4Ghz should work
    Workarounds are
    - disable DFS on your router, but this impacts every device on teh WIFI
    - disable the 5Ghz band on your phone
    (it doesn't seem to be resolved yet in 4.5.2)
    Frederickc likes this.
