wifi issue
  1. ankit7654
    Cupcake May 31, 2018
    ankit7654 , May 31, 2018 :
    i just bought one plus 6 limited addition but i m following wifi issue on it.when i m am connecting wifi it is showing authentication problem..and once if connected then lost automatically.. why i m having this issue and what is fixation of this.please help me.
  2. Dark_Matrix_Guru
    Ice Cream Sandwich May 31, 2018
  3. shahzaan
    Eclair May 31, 2018
    shahzaan , May 31, 2018 :
    Similar issue occurs in my 3t
    In my devce its says authentication failed
    Rejection something like that it says
    I tried everything.. like custom rom original firmware
    More than 10 times i have flash software
    Got nothing.... [e]1f614[/e][e]1f614[/e][e]1f614[/e][e]1f614[/e]
    I hope developer will help you by giving update
  4. Dark_Matrix_Guru
    Dark_Matrix_Guru , May 31, 2018 :
    you may also want to check and make sure that your router is setup to allow this phone to connect. I know personally on my router I only allow 20 IP addresses to be handed out at any given time. you may need to clear the DNS on your router or release and renew your IP address list
  5. ankit7654
    i have clear chache also but nothing happens.same problem occurs.i have brought it today n first day i m having this type of prblm.please help me to get out from this situation
  6. Dark_Matrix_Guru
    have you checked the settings on your router? the phone may be unable to connect due to your router's security settings
  7. ankit7654
    how can i check in my router?please tell me..if i m connecting wifi it is showing authentication problem or wrong password.but password is correct
  8. ankit7654
    sometine wifi is automatically connected and sometime automatically lost network.. please help me what to do
