WIFI Issue
  1. G_Robert_Mackey_TffM Cupcake Dec 2, 2018
  2. Majed.HQ Gingerbread Dec 2, 2018
    Majed.HQ, Dec 2, 2018 :
    I had this issue before and got fixed after I restarted the phone.
    Try it.
  3. jaypt786 Froyo Dec 23, 2018
    jaypt786, Dec 23, 2018 :
    I have faced this issue with my OnePlus one on CM and even on Oxygen OS. now my OnePlus 3T also behaves same.
    hope OP finds a resolution for it.
  4. F1549818390333 Cupcake Feb 10, 2019
    F1549818390333, Feb 10, 2019 :
    I have the WiFi connectivity issue. I use2.4 and 5 GHz router and the issue is getting worse now. Really need the developers to fix this.
  5. Majed.HQ Gingerbread Feb 10, 2019
    Majed.HQ, Feb 10, 2019 :
    if you cannot connect to the 5GHz, make sure that you have the last update 9.0.3 OS.
  6. F1549818390333 Cupcake Feb 10, 2019
  7. Majed.HQ Gingerbread Feb 10, 2019
    OK, try to remove (delete) the network, and add it manually.
    This also worked to some users.
  8. F1549818390333 Cupcake Feb 10, 2019
    Restarted, power off, delete network, literally slapped the phone on my hands! Guess the result? Came back after 30 mins and then the WiFi signal came back.
  9. Majed.HQ Gingerbread Feb 10, 2019
    I gave you the main two issues but it seems that I can't help you with this.
    However, there are still some tips to solve this problem (They may help, the may not). Look for them.
