5
Wifi issues after update 10.5.8 - OnePlus 8 Pro via OnePlus 8 Pro
  1. Defiance3
    Cupcake May 22, 2020
    Defiance3 , via OnePlus 8 Pro , May 22, 2020 :
    Hey all,
    Has anyone been experiencing wifi connectivity issues since they updated to 10.5.8? Since then, my wifi has been disconnecting pretty regularly and my other devices have no issues.
  2. dpgx81
    Honeycomb May 23, 2020
    dpgx81 , May 23, 2020 :
    Having a similar issue. When my device goes to sleep and i wake it, I am finding that i need to disable my wifi and re-enable it to get my connection back.
    T1551558871220 and housry23 like this.
  3. Hdfxsts
    Gingerbread May 23, 2020
  4. housry23
    Ice Cream Sandwich May 24, 2020
    housry23 , via OnePlus 8 Pro , May 24, 2020 :
    Yes this will fix the issue temporarily. The issue is, we paid $1000+ for this phone. Should I really have to toggle WiFi on and off several times a day just for basic phone functionality to work. I can't get texts, messages, calls, emails or any other form of communication on a communication device that I paid a lot of money for. I absolutely have to have these functions to do my job. I'm going to have to go back to my Pixel and leave OnePlus behind.
  5. ctonylee
    Gingerbread Jun 1, 2020
    ctonylee , Jun 1, 2020 :
    Wa la. No more disconnects after changing my MAC privacy setting to "Use device MAC" and change from default "Use randomized MAC". Been going all day with no drop, it's been making me crazy!
  6. bkrickles
    Froyo Jun 1, 2020
    bkrickles , Jun 1, 2020 :
    I hope you're right. I just made the change so I'll see how it goes. I've had some kind of wifi issue and, also, couldn't figure it out.
    Fingers crossed 🤞.
  7. ctonylee
    bkrickles likes this.
  8. ctonylee
    Did it work?
  9. bkrickles
    Froyo Jun 1, 2020
    I'm cautiously optimistic but I just did it last night and I went to my office at 6am today so I only had a few hours with the new setting.
    I'll be home early this afternoon and I'll see how it goes the rest of the day.
    How about you? Still solid?
    And has anyone else on here done this and have results?
    Thanks again!
  10. ctonylee
  11. CrimsonSoul96
    Cupcake Jun 2, 2020
    CrimsonSoul96 , Jun 2, 2020 :
    Fastest order i have recieved, only 4 days from Poland to Croatia.
    The phone works perfect, the screen, the speakers. Its super fast and looks cool.
    never had any problem with green tint, black crush or drm lv3 (its l1).
    battery lasts good 7h heavey usage 4k 120hz.
    buy it u will not regret it.
    Chinda likes this.
  12. GodTamIt
    Froyo Jun 3, 2020
    GodTamIt , Jun 3, 2020 :
    This did not fix any issues for me. Most of the time, my WiFi is still connected but will have "limited connectivity" while all of my other devices are fine. I've interacted with the bug hunters but have yet to hear anything back.
  13. Xaviering
    Cupcake Jun 3, 2020
  14. WokTheDog
    Froyo Jun 5, 2020
    WokTheDog , Jun 5, 2020 :
    If I use Whatsapp or Viber everything is fine, just can't send MMS messages. :-(
  15. B1591561057277
    Cupcake Jun 7, 2020
  16. G_Lisa_Goldbaum_AZyw
    Eclair Jun 8, 2020
    G_Lisa_Goldbaum_AZyw , Jun 8, 2020 :
    I can't believe this but I think that actually worked! Was driving me absolutely insane thanks!!
    ctonylee likes this.
  17. ctonylee
    Gingerbread Jun 8, 2020
    ctonylee , Jun 8, 2020 :
    I'm still going strong. No disconnects and it's been longer than a week.
    G_Lisa_Goldbaum_AZyw likes this.
  18. tentousama
    Cupcake Jun 10, 2020
    tentousama , Jun 10, 2020 :
    I'm still having this issue even with the latest update and setting the MAC address to use the device MAC. Anyone else or is it just me?
  19. B1591561057277
    Cupcake Jun 11, 2020
    B1591561057277 , via OnePlus 8 Pro , Jun 11, 2020 :
    i dunno if this helps someone somehow, but I found out that was my router at home, I was using a Synology with smart wifi, I tried to use the ISP router wifi, and since that moment my wifi is petect. already 3 days without a single disconnection and before was around 2-3 mins
  20. tentousama
    Cupcake Jun 12, 2020
    tentousama , via OnePlus 8 Pro , Jun 12, 2020 :
    yea, I think it has to do with some ax features, it drops off less on my non Ax 5ghz wifi, and not at all on 2.5 GHz. super lame since it's the only device I own that is ax compatible but it's also the only one that has issues on my ax network ._.
