45
Wifi issues on Oneplus 7T after Android 11 update
  1. Jassi101
    Cupcake May 5, 2021
    Jassi101 , May 5, 2021 :
    Same here I am also facing this issue
    domcole likes this.
  2. hyzteric
    Cupcake May 5, 2021
    domcole likes this.
  3. sanjeet286
    Eclair May 5, 2021
    domcole and Vidhit like this.
  4. Vidhit
    Eclair May 5, 2021
  5. JR_Prince
    Donut May 5, 2021
    JR_Prince , via OnePlus 7T , May 5, 2021 :
    Wiping cache didn't work. Try to reset the wifi configuration in reset menu and connect only to 2.5 wifi... Don't add 5ghz. If you do that it works and no disconnection
  6. Lalitkumar4
    Eclair May 5, 2021
  7. Dheeraj555
    Cupcake May 5, 2021
    domcole likes this.
  8. Sil04 and Dragunov like this.
  9. TheMystic
    Lollipop May 5, 2021
    TheMystic , May 5, 2021 :
    Settings/ WiFi & Network/ WiFi/ WiFi Preferences/ Intelligently select the best WiFi.
    Disable it.
    If your router doesn’t list 2.4GHz and 5GHz bands with separate SSIDs, then ‘forget’ the 5GHz connection.
    Reboot, if necessary.
    kt@240997 likes this.
  10. selvamthenarasu8
    Gingerbread May 5, 2021
  11. joelv24
    Cupcake May 5, 2021
  12. Aaron2017
    KitKat May 5, 2021
    Aaron2017 , May 5, 2021 :
    You can try turning of intelligently select the best wifi and if you've got both 2,4 and 5 ghz bands deleting one of them. I don't have those problems myself but this workaround has worked for a lot of other 7t users
  13. NoFate_NoFear , via OnePlus 7T Pro Haze Blue , May 6, 2021 :
    Update Wi-Fi:
    it not only changes the available connections between 2.4-& 5GHz with a full cutdown for Seconds but also between ONE SSID on two AccessPoints when "auto connect" activated...
    funny (...uuuhm - NOT!) for this High-End-ONE+-Smartphone 'cause the crampiest, cheapest, simplest China-PhoneThing can do this without any problems! 👍🏼
    Does anyone know if/when there will be a solution for this huge failure? And - it IS a huge failure! Definitely!!!
  14. NoFate_NoFear , via OnePlus 7T Pro Haze Blue , May 6, 2021 :
    Update:
  15. T1599937128286
    Cupcake May 6, 2021
  16. drvgarg
    Donut May 6, 2021
    Vidhit likes this.
  17. KaustubhNaik95
    Gingerbread May 6, 2021
    Vidhit likes this.
  18. stbxxl
    Donut May 6, 2021
    stbxxl , May 6, 2021 :
    Yeah I had the same issue on my HD1907 after updating to Android 11. And I only use 2.4 GHz.
    I found that turning off Private DNS (in Settings / WiFi & Network) made the Wi-Fi connection way more reliable. In fact, I can't even remember having seen this issue after I made the change.
  19. Dragunov
    Cupcake May 6, 2021
    Dragunov , via OnePlus 7 Pro , May 6, 2021 :
    This option not working
  20. kt@240997 , via OnePlus 7T Glacier Blue , May 6, 2021 :
    Thnks mate this worked
    TheMystic likes this.
