45
Wifi issues on Oneplus 7T after Android 11 update
  1. villapx
    Cupcake May 6, 2021
    villapx , May 6, 2021 :
    Does it have to do with the new "Smart Wi-Fi Connection" settings? I noticed that what's been happening to me specifically is that my phone is bouncing back and forth between my 2.4GHz and 5GHz networks, as others have alluded to (i.e. the workaround of "Forgetting" one of them).
    I noticed that there's a new settings section, I think with this Android 11 update, called "Smart Wi-Fi Connection". It's under Settings > Wi-Fi & Network > Wi-Fi > Wi-Fi preferences. Under this section, the setting Intelligently select the best Wi-Fi was enabled. The description of this setting is, "Intelligently select and connect to the best Wi-Fi by detecting and analyzing the connectivity of Wi-Fi networks".
    I've just turned this setting off, and although it's only been a couple minutes, my phone hasn't been bouncing back and forth between my two Wi-Fi SSIDs anymore. I'm curious for others to try changing this setting and seeing if it stops the behavior.
  2. Dragunov
    Cupcake May 6, 2021
  3. TheMystic
    Lollipop May 6, 2021
    TheMystic , May 6, 2021 :
    You can mark this question as solved.
  4. TheMystic
    Why should you re-enable something that is causing a problem?
  5. Dragunov
    Cupcake May 6, 2021
    Dragunov , via OnePlus 7 Pro , May 6, 2021 :
    I am interested in the problem and its possible cause. This requires some experimentation :)
  6. TheMystic
    This is a bug in the OS.
    Some people have said it doesn't help unless they 'forget' the 5 GHz band, even though the router broadcasts it with a separate SSID.
    But yeah, nothing wrong with experimenting.
    Dragunov likes this.
  7. KaustubhNaik95
    Gingerbread May 6, 2021
  8. Vidhit
    Eclair May 7, 2021
    Vidhit , via OnePlus 7T , May 7, 2021 :
    There is no issue when u have only 1 of 2.4 or 5ghz connected.
    It happens when u have same network with on both Bands.
  9. mayank_gupta1905
    Cupcake May 7, 2021
    mayank_gupta1905 , via OnePlus 7T , May 7, 2021 :
    Since the update to Oxygen OS 11, my device disconnects from WiFi automatically in every 10-15 mins and then reconnects after 10- 20 seconds. My device is OnePlus7t and this is getting very annoying.
    domcole and bplesa like this.
  10. pablofg1978
    Head Moderator Head Moderator May 7, 2021
    pablofg1978 , May 7, 2021 :
    Thread merged
  11. H1533946263415
    Cupcake May 7, 2021
    domcole likes this.
  12. stbxxl
    Donut May 7, 2021
    stbxxl , May 7, 2021 :
    Well, I have only one band active (2.4 GHz) and I do have this issue.
    domcole likes this.
  13. domcole
    Cupcake May 7, 2021
    domcole , via OnePlus 7T , May 7, 2021 :
    I've recently done the android 11 update, and I've noticed that my wifi keeps disconnecting every few minutes and then reconnecting despite there being a stable connection with no issues
  14. Aaron2017
    KitKat May 7, 2021
    Aaron2017 , May 7, 2021 :
    A lot of others got it working again by disabling intelligently select the best wifi and if you have both 2, 4 and 5 ghz bands connected, deleting one of them
  15. H1577977932646
    Cupcake May 8, 2021
    H1577977932646 , via OnePlus 7T , May 8, 2021 :
    After updating the new android 11 update in the OnePlus 7t , ii am facing issue with wifi as most of the time wifi gets disconnect and re connect which cause problems
    If you all are facing same issue please share this and let it reach oneplus
    domcole likes this.
  16. pablofg1978
    Head Moderator Head Moderator May 8, 2021
    pablofg1978 , May 8, 2021 :
    Thread merged
  17. pablofg1978
    Thread merged
  18. 31вεηηλ
    Cupcake May 8, 2021
  19. Dheeraj555
    Cupcake May 8, 2021
    NoFate_NoFear and OmarbAhmed like this.
