Wifi issues with my oneplus
  1. krishjh
    Froyo Aug 23, 2014
    krishjh , Aug 23, 2014 :
    Hi,
    my wifi connection at home sometimes is intermittent, I found that the wifi icon turns orange and stays that way even after the wifi connection comes up, only if i toggle between wifi off and on does it work, is there any resolution for this?
    Regards,
    Murali
  2. zwaene
    Honeycomb Aug 23, 2014
    zwaene , Aug 23, 2014 :
    this is probably an issue that will be fixed in a software update.
    Have you got the latest update?
  3. krishjh
    Froyo Aug 24, 2014
    krishjh , Aug 24, 2014 :
    i am an andriod noob :) , just switched over from iphone, what update are you referring to?
  4. polthergaist
    Cupcake Aug 24, 2014
