2
wifi issues via OnePlus 7 Pro
  1. RohinBhargava
    Donut Oct 21, 2019
    FAFM9 and K1566754327981 like this.
  2. FAFM9
    Cupcake Oct 25, 2019
    FAFM9 , Oct 25, 2019 :
    YES! Facing the same issue ever ever since I've upgraded to Android 10. Keep getting a notification saying internet not available every few minutes. Very annoying.
  3. jasemanONE
    Gingerbread Oct 25, 2019
  4. JNiemi
    JNiemi , Oct 25, 2019 :
    Do mobile, Wifi and bluetooth reset, it can be found in settings -> system -> recovery options -> reset mobile, wifi and bluetooth.
    It wont delete your data or files safe to use and solve much wifi and/or mobile problems.
    H1568890239447 likes this.
  5. RohinBhargava , via OnePlus 7 Pro , Nov 2, 2019 :
    The issue is not resolved. this is becoming a big annoyance. It's not even 3 months since i bought the device. all other device in my house is not facing this issue. so makes it even more annoying.
  6. jasemanONE
    Gingerbread Nov 2, 2019
    jasemanONE , Nov 2, 2019 :
    Did you try the suggested network reset? I would say to do it and at the same time reboot your router. After your router reboots redo your WiFi settings.
  7. #7
  8. fahadkbhatti
    Cupcake Nov 2, 2019
    fahadkbhatti , via OnePlus 7 Pro , Nov 2, 2019 :
    Hello guys, I have just purchased OnePlus 7 Pro. I am facing a very strange very frustrating issue. From time to time My Network totally breakout i.e Wifi Mobile Data both. infact Mobile SIM also go missing. Any idea why it's doing that?
  9. RohinBhargava , via OnePlus 7 Pro , Nov 5, 2019 :
    don't know the issue. but after downgrading to android pie. My battery life has become so much better. Getting 1+ day even with 90hz on. Something is not upto the mark with Android 1p release for 7 pro
    arabinow likes this.
