Wifi limited connection and disconnect via OnePlus 9 Pro
  1. Gitiaruu
    Froyo Sep 18, 2021
    Gitiaruu , via OnePlus 9 Pro , Sep 18, 2021 :
    Everytime I try to connect to a Huawei repeater from Vodafone at the beginning the speed is very limited around 5mb/s both in 2.4ghz and 5ghz and then shows an exclamation mark next to the wifi and disconnects.
  2. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Sep 18, 2021
    Liehjan , Sep 18, 2021 :
    Try to reboot the repeater.
  3. Gitiaruu
    Froyo Sep 18, 2021
  4. Liehjan
    Have you tried to reset network settings on your phone?
  5. Gitiaruu
    Froyo Sep 18, 2021
    Yes and chose use device Mac instead of variable, also static IP and nothing worked.
  6. Legitti
    Gingerbread Sep 19, 2021
    Gitiaruu likes this.
  7. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 19, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Sep 19, 2021 :
    My home WiFi works perfectly fine with every device. But not Nord CE. I have reported it via the feedback tool and collected several logs to try to gather proof.
    Any software updates on the repeater perhaps? What else exists than the repeater? Or do you mean it's a mobile Internet router?
  8. Gitiaruu
    Froyo Sep 21, 2021
    Gitiaruu , via OnePlus 9 Pro , Sep 21, 2021 :
    Every other device works flawless providing wifi, just this wifi repeater gives me trouble. The repeater works with every other device I use ( other phones, computer tablet, android box etc) my phone is the only one that gets "rejected" and gets limited connection
