WiFi- mobile network problem
  1. yanmc89 Donut Apr 17, 2015
    yanmc89, Apr 17, 2015 :
    Apparently after I updated to cos12 whenever I connect to WiFi my mobile signal will keep disconnect and reconnect every few minutes and it's getting annoying.
    I also felt that due to above problem my battery drain is worsen. My phone went from 85% to 65% overnight in Idle status.
    Anyone have solution regarding this?
    G_pratik_patel_IlTC likes this.
  2. rhk95 Cupcake Apr 17, 2015
    rhk95, Apr 17, 2015 :
    I think it enables mobile data when it can't access net over WiFi. The battery drain may also be caused by wakelocks. Since flashing cos12, the lowest my CPU has ever been is 300MHz
  3. yanmc89 Donut Apr 17, 2015
    Bro it's not about mobile data, it's the mobile network signal lost and found every few minutes.
  4. Keith Yuen Donut Apr 26, 2015
    Keith Yuen, Apr 26, 2015 :
    Same problem here, but WiFi signal has been bad since CM11. Battery life has been poor after CM12, even after the most recent update!
  5. E1557665895284 Cupcake May 12, 2019
